350 olds
350 olds
Hi,
I live in Puerto Rico small block are hard to find not to mention big blocks. I found a 350, These are the block numbers 395558 and heads are #8 with a four barrel intake. I know the heads aren't the best but can they be upgraded for some performance what modification do? to used these #8 Heads and mild cam
From what I am seeing posted on the forums, these heads are a low compression "smog" head. You may want to try and look around to see if you can find something a little older, such as a set from a 330, or from an early 350. I am, by no means, an expert on the Olds motor, and only passing on what I am seeing posted.
PR is practically part of the USA
pretty sure we can easily send heads there.
8's on a 395558 casting 350 can be a fine motor if you do not need super high compression. What octane gas can you get/ afford?
W31 flat pistons and 040 gaskets and #8 heads would probably get around 9:1 compression but I have not run the math....
Number 8 heads need work in the bowls, exhaust especially. There is a lip just under the valve that needs ground out. They already have 1.625" exhaust valves, just 2" or 2.07" intake valves.
Oh, they're completely part of the USA, Chris.
They just can't send voting representatives to Congress, so they've got Taxation Without Representation, just like our brothers in Washington, DC.
Nice looking car, Marti! Welcome to ClassicOlds.
