307 loss of power, High idle
Old Jan 22, 2025 | 04:55 PM
Jayshizzle's Avatar
Hey guys, had a few questions. Recently picked up an 84 lesabre, it's got 80k kilometres on it and the engine seems mechanically sound, its a 307 olds. I've been driving it short distances, doesn't stall unless I'm in reverse and don't give it enough gas.
When I get up to highway speeds it stutters and I experience loss of power. I've been doing a bit of research on it and discovered it could be a vacuum leak somewhere, I don't hear anything but I have a pressure tester so I can test it, problem is I don't know which line to go off of. There isn't a whole lot of info on pressure testing this particular engine, that I could find anyways.
Also might be the fuel filter, I ordered one and am due to replace it, something concerned me a bit though, whoever owned this before me, JB welded the large nut. Don't know if there was a leak or something, not sure. Will I still be able to take the fuel filter off or am I fuckered? I have to use 2 wrenches to take it out, is the JB weld just there because someone didn't want to mess around with 2 wrenches? Maybe stripped it? A little concerned about that one.
I'm a little bit new to the scene, I haven't owned a car with a carburetor before so this is all new territory for me, I know it's not the ideal carbureted engine to start on. The carb looks gummed up, so it could also be that right? If I had to guess its got something to do with the fuel, either the injectors or something else.
I thought one of the lines might be frozen since the guy told me it's been sitting since July and it's now winter, I live in extreme cold. I put de icer in there and some sea foam, to clear out the lines and injectors hopefully but it did not work unfortunately.
Does anyone have any ideas for what it is? Any knowledge or tips would be appreciated, trying to learn as much as I can about these old engines.
Thankyou.
Old Jan 22, 2025 | 06:47 PM
Welcome. Your car has the Computer Command Control system (CCC), which is the computer-controlled carb. The computer also controls the advance curve on the distributor as well as some of the emissions equipment. There are also about a bazillion miles of vacuum lines on that engine, and a leak or wrong connection in any one of them will give the CCC system apoplexy. This car has a computer that stores error codes, but it is a relatively stupid system designed with 1970s technology. There are far more failure modes that WON'T set an error code than ones that will. The best thing to do is to get a factory service manual and follow the diagnostic charts carefully. Rebuilding the carb and replacing the vacuum lines would be a good idea, but be aware that this carb MUST be adjusted with the carb on the engine and the engine running. There is a detailed adjustment procedure in the factory manual and you must follow it exactly. Try to take short cuts and you'll just end up chasing your tail.
deltsanddueces
Dec 16, 2020 08:16 AM
pa.kevin1
Sep 24, 2017 10:43 AM
GetDown
Non-Olds Engines
89
Jul 31, 2015 08:57 PM
OldSchoolMuscle71
Aug 13, 2012 11:55 PM
dadweiss
Mar 11, 2008 11:23 AM
