307 to a 403?
307 to a 403?
i have a 86 cutlass supreme with the 307 with a four barrel on it. i've heard that the 403 is exactly the same just bigger bore size and different heads. im just wondering if this is true and how hard it would be to make my 307 into a 403
All SBO and BBO are EXACTLY the same on the outside, the BBO's are a little bit wider and taller, but anything with an Olds motor in it, will be an easy swap for a different Olds motor.
I realize what you are saying but to someone who is new to the concept or just browsing the forum they may get the wrong idea. Wording is the key to correct info.
[QUOTE=InfoJunkie;230594][quote=Redog;230427]EXACTLY the same on the outside, the BBO's are a little bit wider and taller,
Glad to see that someone is filling in as the designated smart-a$$ in my absence.
I have 2 rulers exactly the same. One is 12 inches long the other is 13 inches long.
Meh, you're right. I just don't want to see this guy go buy a 455 intake manifold and try to put it on his 350
