1st OLDS 1967 CUTLASS SUPREME CONVERTIBLE
I just picked up a 1967 Olds Cutlass Supreme Convertible. I am trying to figure out the body tag. Any help would be appreciated. I have most of it figured out just a few questions. 1. the trim says 978-B (978 is yellow, what is the B?) 2. Paint says Y-8 (Saffron is the Y, but what color is the 8? I am guessing that is the convertible top color?) 3. accessory codes 2XG 5Y(the 2XG is on top of the 5Y with the 2 directly above the Y, if that makes a difference). I did see someone quested 5VY as deluxe seat belts this car does have deluxe seatbelts. Yellow with Yellow interior and a white top(top is newer) The car was made in Lansing. 2nd week in February #2936 off the line. Thanks
The color "8" is the convertible top color, which is yellow. 978 is the interior color, which is yellow. B must be some sort of option code (bucket seats?). The other codes I don't have but others here do and they will let you know.
Randy C.
Randy C.
The cowl tag codes are kind of different to figure some times. But, 2xg means= 2- second section of options, x- 2 spd automatic transmission ST-300 commonly called a jetaway, G-means console.
Hope this helps
Larry
Hope this helps
Larry
978-B : 978=Cutlass Supreme yellow interior & B=STRATO bucket seats
Y-8 : Y=saffron body paint & 8=yellow convertible top
2XG : Group 2 - X=2-speed automatic & G=sport console
5Y : Group 5 - Y=deluxe seat belts
02B : 2nd week in February
2936 : 2,936th Cutlass Supreme convertible body (33867) at Lansing (since start of '67 production)
they made the yellow interior with "tan" accents/upper dash "early" VS. "black" accents/upper dash "late"
I have a "02A" Fremont built CS with the yellow/tan interior ..... is your car's also yellow/tan?
71Viking Blue
April 9th, 2013 07:57 PM
