1979 cutlass supreme 5 speed
Old December 4th, 2018, 07:43 AM
Penagarcia's Avatar
I just got a 1979 cutlass 5 speed can anyone tell me more about this car , has Rebuiled motor with less than a 1,000 miles the guy put a 307 Rebuiled in it it runs nice everything under the front end is new , I haven’t decided if I will keep it or sell it I’m probably going to paint it first
Penagarcia is offline
Old December 4th, 2018, 04:05 PM
Welcome. That trans is the Borg Warner T-50, which is probably the only five speed that is weaker than a T5. For this reason it was only offered behind the Buick V6 and the Olds 260 V8. The 307 is a powerhouse compare to the 260. Good luck with it.
joe_padavano is offline
Old December 4th, 2018, 04:08 PM
RandyS's Avatar
In other words, don't beat on it unless you want to be buying a new transmission........
RandyS is offline
Old December 4th, 2018, 04:29 PM
Sugar Bear's Avatar
Was the car a factory five speed? Since the engine was changed maybe it also has a different five speed trans. Keep fresh high quality fluid in it and don't push it hard.
Joe, Is the T-50 the same trans that was in 76' Starfire? I had one with the Buick V-6 and the owners manual advised to add a 90 degree pipe fitting to the fill plug and top that with extra fluid while towing. Wasn't clear on whether they meant towing a boat/trailer or while the car was being towed by an RV etc. I added the fitting, towed a boat a lot and never had a problem.
Sugar Bear is online now
Old December 5th, 2018, 03:09 PM
Yes, it is.
Tony85cutlass
May 30th, 2015 09:50 AM
1968ragtop
45
March 27th, 2015 05:43 PM
Akoostics
August 21st, 2011 09:05 AM
1968ragtop
February 23rd, 2011 12:57 PM
sbs4332
September 30th, 2006 09:39 AM
Quick Reply: 1979 cutlass supreme 5 speed
