1973 Delta 88
1973 Delta 88
I Have A 73 Delta 88 I was wondering can I easily switch to a tilt steering column from a none tilt ? or do anyone know where I could find a replacement column that would fit tilt or none tilt I just need a replacement
One of our members; bigdooly, often parts the 71-76 Olds 98s and Delta 88s. Send him a PM and see if he has the parts you need. Here's a recent thread of his:
https://classicoldsmobile.com/forums...-coupe-154260/
Yes, a tilt column from a 1971-76 GM B-body or C-body is a bolt-in swap. Be aware that the ignition switch (the electrical switch, not the lock cylinder) is different between tilt and non-tilt columns. The harness plugs will need to be rotated 180 deg to plug in.
