1972 cutlass
Old Oct 19, 2010 | 04:55 PM
joe bullet's Avatar
1972 cutlass
guys,
just bought a 1972 cutlass s from a guy in Florida and i am having problems
with idle and bottom end speed . I found paperwork for a comp cam the guy
i bought the car from install and has a 520 lift . Got the car running sounds good
sitting but when it put in drive has no power and barely any brakes . does anybody have any ideas on what this could be .
Old Oct 19, 2010 | 05:11 PM
cutlassjoe's Avatar
Originally Posted by joe bullet
guys,
Sounds like the cam is too wild for the car. The brakes are not working because there is not enough vacuum being created. I ran into this with my engine build on my 72' 350. I am not sure what specs the cam has now, but it still idles lumpy, gets up and goes, and the power brakes work. I am sure someone here can give you more info on it.
Old Oct 19, 2010 | 05:16 PM
joe bullet's Avatar
thanks Joe hopefully somebody has a solution so i dont have to tear into the motor oil
pressure is great no leaks cooling system is all new . basically its all body work on this
car.
Old Oct 19, 2010 | 05:38 PM
InfoJunkie's Avatar
InfoJunkie
Get a 2800-3200 stall convertor, maybe a set of gears, check timing for lack of power.
Get aux vacuum canister ( I think Comp Cams & Moroso make them) for the brakes.
For now don't pump them, just one motion from when you apply them to when the car stops.
Old Oct 19, 2010 | 05:56 PM
joe bullet's Avatar
thanks i will look into aux canister for the brakes . my biggest problem i cant idle and when
you try to adjust the carb it has no change .
Old Oct 19, 2010 | 06:24 PM
joe bullet's Avatar
does anybody have a diagram for vacum lines on this 1972 350 want to double check and
make sure everything is right .
Old Oct 19, 2010 | 07:16 PM
lshlsh2's Avatar
71 cutlass convertible
I sure that someone can get you the diagram. You probably will want to get a 1972 chassis service manual. You can find on ebay for 25-40. It will be the best money you will spend.
Larry
Old Oct 19, 2010 | 07:44 PM
InfoJunkie's Avatar
InfoJunkie
What brand are the intake and carb on your engine?
Old Oct 20, 2010 | 10:54 AM
joe bullet's Avatar
Edelbrock carb and intake
Old Oct 20, 2010 | 06:44 PM
InfoJunkie's Avatar
InfoJunkie
They're both good. You may have to get a convertor or get a smaller cam. I had same promblem with my 350 many years ago. I cured the problem with a 455.
Old Oct 21, 2010 | 04:52 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. Looks like you already have some answers to important questions you had. This site has lots of knowledge and members are willing to share it.
Old Oct 21, 2010 | 05:49 AM
citcapp's Avatar
Welcome to CO
Hang in there, we'll help you find the solution to your problem. Have you checked for vacuum leaks around your carb base an intake. Use carb cleaner or wd-40 and spray around the areas if the idle speed increases you have a leak.
Old Oct 21, 2010 | 07:15 AM
70 cutlass s's Avatar
I would look for vacuum leaks like Pat said. If you don't find one on the engine. Look at the brake booster test it out to find it has a vacuum leak.
Old Oct 21, 2010 | 04:43 PM
joe bullet's Avatar
thank very much i will do these test and let you guys know what happens.
Old Nov 3, 2010 | 04:45 PM
joe bullet's Avatar
guys thanks for all your help i found the rear rubber intake gasket was pinch .looks like the
install incorrectly . someone told me not to use the rubber gasket and use gasket sealer
instead . have you guys replace the manifold and do you have gasket or silicone .
joe bullet's Avatar
hopefully i could put it together this weekend and get it running.
Old Nov 3, 2010 | 04:58 PM
ziff396's Avatar
Myself, I throw away the rubber one's. Especially if the intake is aluminum. Just my opinion.
Gotvette?
Jan 9, 2015 06:42 PM
travisbeamon
Apr 6, 2013 09:37 AM
Oldssupreme
Jan 14, 2013 10:08 AM
rallye350
Dec 23, 2009 08:11 PM
egknz
Oct 26, 2009 06:06 PM
