1972 cutlass
1972 cutlass
guys,
just bought a 1972 cutlass s from a guy in Florida and i am having problems
with idle and bottom end speed . I found paperwork for a comp cam the guy
i bought the car from install and has a 520 lift . Got the car running sounds good
sitting but when it put in drive has no power and barely any brakes . does anybody have any ideas on what this could be .
guys,
Get a 2800-3200 stall convertor, maybe a set of gears, check timing for lack of power.
Get aux vacuum canister ( I think Comp Cams & Moroso make them) for the brakes.
For now don't pump them, just one motion from when you apply them to when the car stops.
Welcome to CO
Hang in there, we'll help you find the solution to your problem. Have you checked for vacuum leaks around your carb base an intake. Use carb cleaner or wd-40 and spray around the areas if the idle speed increases you have a leak.
guys thanks for all your help i found the rear rubber intake gasket was pinch .looks like the
install incorrectly . someone told me not to use the rubber gasket and use gasket sealer
instead . have you guys replace the manifold and do you have gasket or silicone .
Gotvette?
Jan 9, 2015 06:42 PM
egknz
Oct 26, 2009 06:06 PM
