1971 Cutlass Convertible
Hello folks. New to the site and this is my first Olds.........
Looking for opinions on what fluid changes to make on this recent purchase..... Would like to do as much as possible before winter....
Thanks!
Thanks!
Welcome to the site, nice car. If the trans fluid is a pretty red color, leave it alone. If the coolant is clear and green, tests to the proper temp for your area, leave it alone. If the brake fluid is clear inside the master cylinder, leave it alone. If the engine oil is not black leave it alone. Check the level of the rear end, add as required. Top power steering and windshield washer. Pull it into the garage, disconnect the battery, and let her hibernate till spring. When spring time comes, change the engine oil, and enjoy.
Over the winter I would pull the wheels and check the condition of the brake system/ rubber hoses and wheel bearings/races. Repair/replace as necessary and repack the bearings. Inspect the front end, front and rear suspension, steering components, repair as required and get a front end alignment. Inspect rubber fuel lines and check/or perform a tuneup. Change air filter and fuel filter.
Unfortunately the previous owner didn't have the time to take care off that. Pretty much every fluid you mentioned was black like the exterior paint! I know it will take some time but looking to get all those fluids changed ...... just looking for suggestions as to what order would be most beneficial..... looking to bring her back to life......
Cowl Tag Info 1971 Cutlass Supreme
Looking for some information on this Cowl Tag to see what my 1971 Cutlass Supreme original came with. Thanks in advance..........
In regards to the cowl tag.
ST 71, 1971 model year
342, cutlass supreme
67 convertible
M, Lansing plant
XXXXXX build sequence
Z used most of 1970 and most of 1971 on select cars no rhyme or reason unknown code
989 Sienna color notched bench seat
61, Sandalwood paint
E, Sandalwood color top
02, Feb month of start of build
C, 3rd week of month
67 convertible
M, Lansing plant
71cutlassdroptop
September 18th, 2017 06:09 PM
caguirre0488
November 23rd, 2015 02:40 PM
Chuckthizzle
May 26th, 2015 07:40 PM
Gotvette?
January 9th, 2015 06:42 PM
