1969 442 key cylinder switch
I believe the plastic shaft that pulls the teeth on the rail is broken I need a pic of one and how to replace it , do I have to remove steering wheel to replace that? ......the old key cylinder was pulled out before car was purchased .thanks for any help
That's called the sector gear. I think if the cylinder is out, you can pull it out with needle nose pliers, I'm not positive. If the cylinder is in, the wheel has to come off. Let me look for a pic.
Letter Coded *** GM *** Ignition Tumbler
If you would like a NEW Ignition Tumbler & keys:
I have two versions of aftermarket (different price)
and 1 last Letter Coded for '69 *** GM *** Ignition Tumbler with keys!!!!!
86ChebbyWagon307
July 5th, 2011 07:09 PM
JMW803
May 13th, 2010 04:43 PM
