1968 Olds 442 Convertible
Old May 31, 2019 | 05:46 PM
Clydesdale2001's Avatar
Does anyone have the answer if a 68 2 door hardtop door is the same as the 68 442 convertible?
Old May 31, 2019 | 05:52 PM
BackInTheGame's Avatar
In what manner? They have the same frame, possibly suspension, nearly identical bodies and trim, same options were mostly available for both. Can you refine your question? In my signature below, the black car is a '68 Cutlass S, while the teal car on the right is a '68 4-4-2 - neither are a convertible, as you can see, though.
Old May 31, 2019 | 06:21 PM
Will the doors from a 68' hardtop interchange with the 68' 442 convertible?
Old May 31, 2019 | 07:09 PM
Yellowstatue's Avatar
The frame on a convert is different than the hardtop. Boxed and therefore shorter trans cross member. The doors will inter change but the vent frames have extra detail for the weather strip. But still usable either way.
That one I don't know. Someone else will have to chime in; sorry.
Old May 31, 2019 | 07:19 PM
Yellowstatue so the convertible has extra vent deatail?
Old May 31, 2019 | 07:48 PM
Yes. If you have both vent frames, you will see an extra rib on the inboard side that the convert weather strip fits into. The hard top has a smooth curve for the weather strip.
Old Jun 1, 2019 | 10:34 AM
bry593's Avatar
1968 442 Convertible
What yellowstatue is saying is that the actual door is the same. You will need to swap out the bat wing assemblies.
Clydesdale2001
May 31, 2019 07:10 PM
classicmuscle442
Oct 13, 2017 05:54 AM
70Post
Sep 13, 2014 10:02 PM
dnmfranco
Nov 29, 2013 06:22 PM
ros6872
Jun 14, 2013 04:00 PM
