1966 delta88 brake conversion
Hey y'all my son was given a 1966 old delta 88 convertible and I am looking to replace the drum brake with disc. And was looking for any suggestion on what might work on it and if any one has a kit. Thanks for any suggestions you might have.
I have the SSBC kit on mine (65 Jetstar 1), and converted to dual line with the proportioning valve. Pretty much everything is in the kit, but it's pricey-about $800. You still utilize your speedo cable set up, which is what makes it tricky if you try to use salvage parts from another car. It stops on a dime, and is a great improvement. You don't have to butcher anything, so you can return it to stock, if you want to go back to pulling to the right and stopping like a transit bus, lol!
disc conversion
JetstarJim,
I have a 65 Olds 98. I realize it is not a Jetstar. When you used the SSBC conversion, did you have an issue with the hubs fitting inside the rotors and your ability to use the 14 inch stock rims?
akins2000
January 22nd, 2012 12:39 PM
