1964 olds cutlass
1964 olds cutlass
Hello everyone. I am curious if anybody can help me locate reproduction parts for a 1964 olds cutlass convertible. I am in need of rear filler panels or trunk extensions (fits between trunk floor and lower rear of the quarter panel behind the rear wheel house). I am also looking for left and right rear inner & outer wheel housings. May also be interested in a left rear used full quarter panel for a 64 hdtp or convertible. Any input would be a great big help. Thanks. lbsauto.
John had a left quarter (2blu442)
Not sure if he still does it was from a 65 should be the same except the tail light panel area located in Orgeon
Also depending on location check with JATA located in Florida
Also (honestdave) located had both left and right but they had bondo fill depending on what's needed
Located in Canada
Located in Canada
The outers match up to the wheel openings, which are different for each brand, thus the outers are different for each brand. Same for the front inner fender panels.
64oldsf85cutlass
Body work
July 4th, 2014 07:06 AM
Kaline
January 12th, 2013 08:37 PM
