1962 Starfire Wheel Bearing Hubs
Old Jun 18, 2023 | 01:09 PM
StarBayB's Avatar
Hello!
I'm the owner of a 1962 Oldsmobile Starfire convertible. Have been looking for a set of front wheel bearing hubs.
I have 3 questions:
1) Does anyone know where I might find them?
2) I was told that full size Pontiacs & Buicks 1959 to 1964 would also fit?
3) How easy is it to convert to a disc break set up?
Any response would be appreciated!!
Thanks.
Old Jun 18, 2023 | 05:48 PM
Why do you need hubs? The bearings and races can be replaced and are readily available. The hubs typically do not require replacement so no one makes them. Unlike newer versions, in the 1960s the full size cars all used unique chassis, suspension, and brakes. I suspect that only Olds parts will work. Be aware that the left hand side uses LH thread lug nuts and LH thread on the spindle nut.
Old Jun 19, 2023 | 05:51 AM
Oldsfan's Avatar
Olds never serviced the hubs on these cars. They are part of the brake drum. You can separate the hubs and drums by chiselling out the wheel studs, but as far as I know there are no replacement hubs available.
forddom
Feb 20, 2023 06:50 AM
Supernice88
Dec 7, 2021 06:25 PM
1961&1962Starfire
Sep 27, 2021 11:47 AM
60193W30
Nov 19, 2020 04:08 AM
hurstoldz
Jun 19, 2012 02:50 PM
