1962 Dynamic 88 alternator conversion
Has anyone ever coverted their generator to alternator in a 62 Dynamic. If so how did you mount the alternator? I'm having trouble figuring a way out. The only was I see is to fabricate a custom tension backet. Is there any other way?
If you don't care about appearance, use the stock alternator brackets but get a 12SI internal regulated alternator from a late 1980s Olds 307. These have 78 amps stock, fit those stock alternator brackets, and are extremely easy to wire. I did this conversion on my 62 F-85 and it works great. Took me about an hour. The hardest part was finding the correct length belt.
I sprung for PowerGEN alternator for my '62 Dynamic. Looks almost identical to the original generator and it works great. Simple one wire hook up using the oiginal brackets (plus an extender piece for the upper arm). Puts out 75 amps and 60 at idle speed.
http://www.powermastermotorsports.com/powergen.html
442mark
September 30th, 2017 01:06 PM
eddieunderground
August 1st, 2012 02:41 AM
