1957 371 j2 carb question
Old Sep 13, 2016 | 02:26 PM
stokerg's Avatar
I recently purchased a nice 1957 super 88 hardtop with the original J2 371. Someone removed the original J2 intake, which I have, and replaced it with an Edelbrock 4 barrel. I'd like to put it back to a tri-power configuration BUT I'd like to set it up with progressive linkage versus the original Rochester vacuum closed/open configuration that it came with. I don't care if its exactly original. I was looking at possibly using Holleys and jetting them down if need be...Thoughts & recommendations??? Thank you
Old Sep 13, 2016 | 05:30 PM
Charlie Jones's Avatar
Phantom Phixer
The only carbs that will fit the J-2 intake are the small based Rochesters (G2 , CG2).
Holley 2 barrels are way too large and will not fit.
The only other possibility are Mopar 318 carbs which have the same base pattern.
Speedway Motors sells progressive linkage kits;
http://www.speedwaymotors.com/Roches...essive,78.html
<GuitarGuyBlue>
Sep 26, 2018 08:06 AM
59-59-59
Dec 5, 2013 02:28 PM
Rowdies
Apr 11, 2012 09:23 PM
blackcherry
Apr 18, 2011 08:25 PM
59-59-59
Jun 13, 2009 02:23 PM
