GM " Oldsmobile " Decals
Old Jan 18, 2023 | 12:21 PM
rickw30's Avatar
GM " Oldsmobile " Decals.
Acquired these from an Olds Dealership in the mid 90's.
​​​​Made of Waterproof UV resistant vinyl.
Decal color is WHITE.
Must be applied to a SMOOTH dry surface.
I have multiples of 3 different types as described in photos.
Pricing INCLUDES shipping to the lower 48 US.
$20 each.
Windshield banner (slightly curved).
Top (#1) - 24" x 3.5"
Bottom (#2) - 27" x 3.75"
#3 Large (straight not curved).
30" x 4.5"
#3 on smooth wall.
I have recently applied over a dozen of these on various smooth surfaces with 0% failure. (Side of my truck, windshield, wall, glass door, tool box, plexiglass for sign ect.)
Method I used for adhering Decal;
- Clean smooth surface with a rubbing alcohol/water mix.
- Peel white paper backing exposing adhesive side of decal.
- Place decal in desired location starting at one side peeling back paper as you press decal into place.
- Rub protective paper and decal with a decal squeegee/scraper.
​​​​​​Be sure to rub all outer edges and corners to promote adhesion.
- Tricky part - Slowly peel protective paper working it back and forth at as close of an angle to the decal as you can get. Be very careful of 90° edges of decal lettering.
NOTE:
Soaking protective paper with a sponge of Dawn soap/water solution will make this easier.
Do NOT apply on cold surface.
Do NOT use soapy water solution on surface for placement of decal.
Thanks for looking.
Old Feb 17, 2023 | 03:48 AM
rickw30's Avatar
Ttt
Old Mar 17, 2023 | 02:53 AM
rickw30's Avatar
Ttt
Old Sep 29, 2024 | 06:24 AM
rickw30's Avatar
Ttt
vette442
Dec 30, 2022 12:59 AM
jopa
May 29, 2021 05:55 AM
jopa
Feb 22, 2020 10:43 PM
Hairy Olds
Oct 25, 2019 02:34 PM
DRXOLDS
Feb 15, 2019 10:59 PM
