Date Codes Questions
Welcome to the site Chuck! There's been some discussion on this in past threads. The search function doesn't work real well, but hopefully someone who has a good idea will speak up. Obviously prior to the build date of your car. But how much before I'm not sure. The block will be easy to find, but the W30 only stampings on the heads, carb, distributor, etc. those items will be harder to find. Not sure if you've found these threads, but they may have some details that would help you with your restoration.
John
https://classicoldsmobile.com/forums...70-w-30-a.html
https://classicoldsmobile.com/forums...nvertible.html
https://classicoldsmobile.com/forums...timelines.html
https://classicoldsmobile.com/forums...890-880-a.html
John
1320dragmonza
Tech Editor's Desk
Aug 17, 2013 04:44 PM
