It's now a frame off!
Old Jul 15, 2012 | 07:58 PM
65 Delta Guy's Avatar
With the A body daily driver I have decided to go from rolling resto to full frame off. With the tank out and all the body bolts I lifted the body off the frame, and rolled the frame out. Next went to removing grease and grime with the pressure washer to keep the tear down a little cleaner. Attacking exaust and brake lines rounde out the day, boxing in the rails is the next item on deck as the 425 will put down over 500 fpt. I am amazed at how much structure is lacking for the girth of these B bodies so boxing more than the frame rails may be called for, I will continue to update!
Old Jul 15, 2012 | 08:38 PM
Red face Oops
Just figured out I should be posting this thread in the resto section (just found it)
Old Jul 15, 2012 | 08:41 PM
Lady72nRob71's Avatar
This will be a fun thread to watch. Not too many do a full frame-off on the big cars so it will be cool to see the differences from the common A-bodies.
Keep the pictures coming!
Oh - I will move this to the major projects section for you - more fitting!
Old Oct 7, 2012 | 09:16 PM
While the motor is coming together I have been at work on suspension parts. After boxing in the lower control arm I cut the bottom off and added a 2" strip and welded the bottom back on, should nestle the springs nicely. I will push in Prothane bushings after powder coating.
Old Oct 7, 2012 | 09:25 PM
I have to ask why? I can see this on the rear lower control arms, but why on the front?
Old Oct 7, 2012 | 09:53 PM
Frame
After sandblasting...I boxed and gusseted the frame before powder coating.
Old Oct 7, 2012 | 09:57 PM
I wanted to get a bit more drop on the front end...had planned on a drop spindle with no luck. The car will have a full air-ride setup and this will ensure a full plant in the weeds at shows...it will roll with an aggressive slightly raked stance when terrorizing the streets!
Old Oct 8, 2012 | 07:22 AM
oldsguybry's Avatar
NOVICE car nut
Wow , that's nice ! You don't waste any time taking that car apart either !
Old Oct 8, 2012 | 03:35 PM
RetroRanger's Avatar
72 Olds CS
65 delta guy
I am adding you to my list of people who rock
Nice thread ...gonna be hard to top w what you've posted so far !!!
Old Oct 8, 2012 | 04:22 PM
Thanks bry...more money would make it go a lot faster for sure! I am trying to do something on it every week in an effort to have it together for shows next summer.
Old Oct 8, 2012 | 04:40 PM
65 delta guy
Retro thanks for saying that...here is a link to the guy I bought this car from, she was pretty good foundation wise!
https://classicoldsmobile.com/forums...light=toddluck
Old Oct 9, 2012 | 07:05 PM
Built a cart to roll the body around the garage and I can trailer it to blaster for interior/firewall/underside removal.
Old Oct 21, 2012 | 08:12 PM
ent72olds's Avatar
Registered Luser
Frame looks great! Keep up the good work!
Old Oct 22, 2012 | 06:20 PM
OLD SKL 69's Avatar
GM Enthusiast
Frame looks great, keep the updates coming.
Old Oct 22, 2012 | 06:31 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Wow, that body looks clean & straight.
This is gonna be an awesome build to watch. Keep up the nice work.
1970-W30
Aug 21, 2013 05:10 PM
sixty9olds
Jun 14, 2011 06:43 PM
oldsdroptop
Jun 2, 2009 07:03 PM
old.n.bold
Mar 12, 2009 12:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
