70 cutlass "s" 455
Old Jun 24, 2012 | 10:42 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
70 cutlass "s" 455
Hey all,
Bought a 70 olds Cutlass "s" arrived fridaynight.
This is the car leaving N.Carolina
THIS IS IT GETTING TO MY HOUSE BELOW SEE VIDEO
http://www.youtube.com/watch?v=POf49mhj8lM
Old Jun 24, 2012 | 10:54 AM
Seems to be a nice rig. We love pic's!
Old Jun 24, 2012 | 08:13 PM
Olds Specialist LOL
Uploaded with ImageShack.us
Old Jun 25, 2012 | 08:06 AM
Joffroi's Avatar
Runner
Cutlass S or real 442? Looks good!
Old Jun 25, 2012 | 08:18 AM
Olds Specialist LOL
Well here is the thing it came with a vin of 336 so im assuming cutlass "s"
it has all the emblems boxed control arms 455 "F" block with E heads.
Probably a optioned cutlass "s" the 442 emblems were already there
Old Jun 25, 2012 | 08:59 AM
Nice car! Thanks for the additional pic's.
Old Jun 25, 2012 | 05:07 PM
Olds Specialist LOL
couple more
Old Jun 25, 2012 | 05:21 PM
droptopron's Avatar
delete
Looks nice. Good luck with it.
Old Jun 25, 2012 | 05:22 PM
ziff396's Avatar
Looks good! How are the floors, trunk etc. Lot's of things can hide. Nice ride.
Old Jun 25, 2012 | 05:30 PM
allyolds68's Avatar
Nice car. Those hoods make the 70's a great looking car.
Nice plate. Where in NY are you? I can't bring myself to buy vanity plates. It's over $100/yr if I remember correctly.
Old Jun 25, 2012 | 07:57 PM
Olds Specialist LOL
Thanks the hood sure does make it look awsum.
center of longisland
here is one i had a few years back maybe do the same with the new one.
Old Jun 28, 2012 | 04:48 AM
Olds Specialist LOL
Data plate
at plate can sombody decode?
Old Jun 28, 2012 | 08:04 AM
jims2000lt's Avatar
11.52 @116
Nice find. Get rid of the side molding and start cruising! Nice car!
Old Jun 29, 2012 | 03:53 AM
Olds Specialist LOL
why thats not factory?
Old Jun 29, 2012 | 05:27 AM
TenMidgets's Avatar
So you have this and the red one going right now? Looks like two great cars to work on...two is better than one!
Old Jun 29, 2012 | 05:49 AM
oldzzy's Avatar
wait.... what....
No, that side molding is not a factory molding. Nice car tho, i like the B85 molding on the doors and quarter windows.
Old Jun 29, 2012 | 01:51 PM
Del70's Avatar
cool... Sherwood green, SS1 wheels and a factory W25 hood, and,,,a southern car? which I assume does not have rusted fenders or quarters...looks like a nice find...
Old Jun 29, 2012 | 02:03 PM
Factory side molding on the Cutlass S looks like this:
EDIT: Side note (no pun intended) 442's did NOT have any body side moldings
Old Jul 14, 2012 | 04:58 AM
Olds Specialist LOL
Good to know i didnt think it was factory thanks!
Old Jul 16, 2012 | 12:52 PM
Olds Specialist LOL
So that's the factory molding correct? B85 i might remove when i paint it.
Old Jul 16, 2012 | 02:33 PM
B85 is the wide anodized aluminum part that is mounted on the top of the door ridge next to the window sweeps. It has a special attachment not found on other cars. If you're going to remove it for repaint, do so very carefully. It's hard to find replacement parts. IIRC Steele Rubber is the only one that makes a suitable replacement, and they're not cheap. BTW the Cutlass S with those moldings is somewhat more rare than finding them on a Cutlass Supreme. It took me almost 3 years to find a set. It's not the door ones that are hard to find, it's the curved ones at the back!
Old Jul 20, 2012 | 12:08 PM
Olds Specialist LOL
Intake and valve covers
Hey all doing my intake and lifters today can't say i have done alot of oldsmobile intakes.
Is there anything i should be aware of LOL wish me luck!
The only problem is one valve cover i bought only has 5 holes in it??? off 403 maybe?
Old Jul 25, 2012 | 04:16 AM
Olds Specialist LOL
Need help lifting this thing on the car help
Old Jul 25, 2012 | 11:34 AM
That was a first for me - seeing only 5 bolt holes. But you're right! Here's a pic of a rebuilt 403.
and another one pulled, you can clearly see there are 'missing' holes.
Now I hafta take a trip to the boneyard to see those 78 Toros they have out there with 403's. Wonder why they did that with the VC?
re: Intake? Yeah they're heavy monsters aren't they? But it's really a one man job. What you could do is put a piec of metal rod across the front of the block to hold up the front intake while you position it at the back, then move the rod out when doing the front. No valley pan? Have a look at this thread for info on the install https://classicoldsmobile.com/forums...tml#post387297
You could also hold it by the Tstat inlet and rear water valve for comfort.
Old Jul 26, 2012 | 07:10 AM
Olds Specialist LOL
Thanks allen yes i have the valley pan!!.
According to that thread you guys dont like to use the rubber end gaskets???or was that just on an aluminum intakes?
And what is with the dimple thing???
i have the stock intake with valley pan i siliconed the corners so far and put the rubber on front and back so it will stay in place. just in the corners not across the center of the robber gaskets. next is water jackets on the block with silicone and on the bottom of the valley pan i will do the same for the intake ports then the valley pan goes on and repeat process of water jacket and intake ports again 1/8 inch bead.
do the 4 coeners again and put the intake on.
i have done many many intakes just this is my second time doing an olds.
did many small block chevies over the years and a pontiac 400 recently all with success.
Old Jul 26, 2012 | 01:25 PM
Yes, you read that right. The comment Steve was giving Roger was to do that for the EB manifold. You're doing it right - don't try and dimple the stock intake. And really if you've done others, the Olds is not a whole lot different. Be sure to let us know how things work out.
Old Aug 3, 2012 | 04:13 AM
Olds Specialist LOL
Got the intake and ram air on
Old Aug 18, 2012 | 05:19 AM
Olds Specialist LOL
Readying for Paint!
It's in the body shop for paint!
still unsure of what color
Old Sep 7, 2012 | 10:09 PM
Olds Specialist LOL
getting close
Old Sep 8, 2012 | 05:24 AM
Eddie Hansen's Avatar
Looking good johnny, what color? And just tell me your not putting that brush guard on her like the general lee lol
Old Sep 8, 2012 | 06:32 AM
  #31
Olds Specialist LOL
No,push guard color Hmmm still up in the air thinking aspen green with black hood stripes
see below
Old Sep 8, 2012 | 06:56 AM
  #32
very nice....
That's a nice color, personally I prefer the darker green that it was but that,s just me, I had a 69gto convertible that was this very light ice blue metallic with a dark navy blue interior and dark navy blue top , at the time I was ok with it but over time it was my absolute favorite color combo, is it a black interior or dark green? If it is dark green I think the light green metallic will be outstanding
Old Sep 8, 2012 | 07:01 AM
  #33
Olds Specialist LOL
Hey Eddie,
Thanks yes it has a black int.
The dark green is nice but i wanted to do somthing different ya know.
Old Sep 8, 2012 | 05:34 PM
  #34
Olds Specialist LOL
Silver???
Old Sep 8, 2012 | 07:40 PM
  #35
Silver will be awesome
Old Sep 24, 2012 | 01:58 PM
  #36
Olds Specialist LOL
Thanks now thinking agean aqua
Old Sep 24, 2012 | 02:09 PM
  #37
TenMidgets's Avatar
How about dark blue w/ white stripes?
http://www.futureclassicsnj.com/clos...pe=sold&page=3
Old Sep 24, 2012 | 02:31 PM
  #38
Silver???
Ding ding ding! We have a winner - just add side stripes. I'm partial to silver....
Old Sep 24, 2012 | 02:32 PM
  #39
Thanks now thinking teal
Teal looks awesome as well
Old Sep 25, 2012 | 05:29 AM
  #40
RetroRanger's Avatar
72 Olds CS
Silver,
aspen green,
the dark green
in reverse order of preference....but its not my car no teal IMHO unless you do pink stripes
