79 trans am 403 install
I have a 79 trans am that I swapped a 301 to a 403. First engine swap and learning as I go and I have started running into problems. Whenever I go to turn the ignition half the time I will not turn over (just makes a quick thud sound and nothing happens) it may do this 2 or 3 times and then it will try to turn over or it could try to turn over on the first turn of the ignition. Whenever it does turn over it sounds very weak almost like the battery is almost dead or pulling pulled down a lot. Battery is fully charged.
Could it be something with the battery? cranking amps? / Could it be something with the starter? It is a new starter / Could it be something with compression?
Thanks for any ideas or input
Don't discount a bad 'new' starter. Could be weak out of the box.
Get a meter and ck battery at rest and under load (during cranking) to see how far volts are dropping. If you have a battery load tester you could ck the battery itself.
Good luck.
Good luck.
what is a reasonable voltage drop? how low should it not go?
it can be rotated with a good bit more force, it has tried to fire a time or two (idle not even close at the moment) and it is an automatic transmission
It does require a good bit of force to get it to turn, and it is turned little by little to go all the way around, not just a continuous motion once it starts. I just want to describe it best I can to forsure rule that out.
You should also be good if you can turn the engine freely and smoothly with the plugs out. With the plugs in compression will make it quite a bit harder to turn.
