1979 Hurst Olds Cutlass
Old Dec 12, 2024 | 08:26 PM
The Fast Forester's Avatar
Hey all! This looks like a great forum for classic Olds cars. I just came across a 1979 Olds Cutlass with the "R" VIN and properly coded trim tag and believe this to be an original T-top Hurst Olds. Not sure how it ended up green and gold with low-rider wheels? I'll plan to start a restoration thread here and see if we can't get it back to as original as possible. Looking forward to learning a lot from this forum!
Old Dec 12, 2024 | 08:35 PM
For starters...brakes are an issue (as in really not working)...so I'll most likely start there.
I'm glad the owner saved the original wheels, those will go back in due time.
Old Dec 13, 2024 | 08:34 PM
www.hurstolds.com They can help you find missing parts and verify it's a Hurst/Olds by the VIN. They have the records.
At least the original wheels came with it. Paint will be your big expense. Was this one originally white, or black?
This one was black.
Some people don't know what a Hurst/Olds really is and don't recognize or understand its significance. All they see is a GM G-body (still technically an A-body in 79) and their tribal instinct kicks in. Next thing you know it's donked out, on stilts, in a color no Hurst/Olds ever came in. Count yourself lucky the molestation is limited to flashy paint and wheels.
They covet this bodystyle so badly that FOUR were stolen from the 2009 Hurst/Olds Club National Meet in Indianapolis. I think only one, a black 79, was ever recovered and when it was located the stripping process had started.
Old Dec 14, 2024 | 09:14 AM
old80cs's Avatar
Good luck bringing it back, look forward to seeing the progress pictures!
Old Dec 20, 2024 | 08:35 PM
Before I dig into this thing thought I'd get as many numbers as I could off the car. Somewhat to my dismay, I cleaned off the engine block number below the #1 spark plug and it didn't line up with the VIN.
My VIN is 3K47R9M552077. The stamped engine code looks to be 37R104042, which would indicate a 1977 engine, and not from the Lansing plant. And the last six of the VIN obviously is nowhere near what I have for a VIN.
The casting number above the water pump on the engine block is 554964 3A...a 350 from 1977-80. Transmission numbers lined up with the VIN OK, and the rear end code looks to be 2.73 gears with no posi. The cylinder heads, intake and exhaust manifolds match up as original, just not the engine block. Oh well, pretty close with the '77 350 rocket in there.
Old Dec 21, 2024 | 05:26 AM
69HO43's Avatar
Keep in mind VIN can be deciphered by anyone to verify it's a Hurst/Olds as long as there's an R for the engine code in the VIN.
That meet brought back some scary memories. I was there at that 2009 H/OCA meet in Indy and my 84 was parked next to an 84 that got stolen from the parking lot. It had T-tops, mine didn't. I'm thinking that's the only reason mine got saved. Who knows? I believe it was Trevor Badgley's 83 that was in a trailer and they got that, too. So it just wasn't 79s.
Old Dec 24, 2024 | 07:28 AM
RAG's Avatar
RAG
I had a white '79 H/O at that meet but it was untouched. My friend's '84 H/O had the door pried open but had a club on the steering wheel so they moved on to the others. Badgley's didn't bother to contract security for the parking lot and didn't close off access to the cars, lesson learned.
Old Dec 30, 2024 | 10:07 PM
Rear drum brakes before and afters.
Old Dec 31, 2024 | 05:04 AM
BlueCalais79's Avatar
Superb job! If you need a source for re-finishing the Gold Hurst wheels, I have one. They may also do the center caps, not sure.
Old Jan 7, 2025 | 10:36 PM
Thanks BC79! Appreciate knowing your source for the wheel re-finishing when you get a chance.
To get this e-brake functioning again I need a new release handle, so that inspired me to tear into the dash a bit. Pretty rough in there but it's a start.
I think the after-market gauges and radio will have to go, I've got the original gauges but not sure if they work or not.
Old Jan 8, 2025 | 02:51 AM
fleming442's Avatar
I'm interested in the gauges, if you decide to get rid of them.
Old Jan 8, 2025 | 09:39 PM
Sounds good F442. I'll be testing these before I remove them, then also testing the originals and see what I have to deal with.
Old Jan 15, 2025 | 10:18 PM
Decided to work on lights for a bit. No power at headlights, had a broken LH tail light and 3 of the 4 fender/quarter lights were'nt working.
Old Jan 16, 2025 | 08:59 PM
A little trunk time tonight.
Old Jan 17, 2025 | 03:46 AM
69HO43's Avatar
You're going to need new pinchweld weatherstripping for that trunk for sure.
GM p/n 20641957, or 25558394, or 20490800. You could buy the aftermarket stuff, but I have absolutely no idea about fit or quality. Nothing I've ever seen aftermarket fits better or seals better than the GM stuff, but it's getting harder to find now. Good luck on the project. Doable, but a long road.
Old Jan 17, 2025 | 05:37 AM
My apologies FF, I failed to check this thread until now. The wheel restorer is Collision Wheel in Bath, PA., they may even have some of the 79 H/O Wheels in stock: www.wheelcollision.com.
In looking at your photos, I've got alot of parts you may want/need, especially interior & dash parts. I have anywhere from used to NOS, send me a P.M. if you are interested, as I can surely assist a fellow 79 H/O Owner.
Old Jan 17, 2025 | 08:35 PM
Thanks 69HO, I've got the weatherstripping bookmarked, thanks for the part numbers.
BC79....thanks for the link, PM sent.
Old Jan 18, 2025 | 01:19 PM
FStanley's Avatar
I found if you have a space saver donut spare, a trunk board that looks like this fits better and was the exact duplicate of what I needed, most of the repro boards are for full size spare tires and are different. some trunk repro stuff is the same as for Monte Carlo and Malibu..
https://www.thepartsplaceinc.com/pro...he-trunk/87041
Old Jan 18, 2025 | 09:29 PM
Thanks Fred!
Old Jan 19, 2025 | 08:11 PM
FStanley's Avatar
FYI I bought some NOS weatherstripping but it was so old it just fell apart on me and I paid top dollar for it like 4 times the price of repro. BUT the repro stuff I tried from Metro wasn't that great did not seem soft enough but it did seal but ya gotta slam the doors to make em shut..
Old Jan 23, 2025 | 09:40 PM
Looks like I'll be keeping and re-installing the after-market gauges. Too much has been altered with the wire harness to attempt to go back to the original dash.
Old Jan 23, 2025 | 09:43 PM
Might need a new battery tray...
This was fun getting out of there.
Old Jan 24, 2025 | 05:27 AM
I have one, I'll look for that as well.
Old Jan 24, 2025 | 12:06 PM
GN1220's Avatar
Looks like the previous owner was worried people wouldn't know what kind of car it is.
Old Jan 24, 2025 | 08:37 PM
Thanks Gene!
Old Jan 24, 2025 | 08:44 PM
Ya, I think I heard him complaining about the price of all those emblems during one conversation. Just the Hurst Olds one should be back there right?
Old Jan 25, 2025 | 03:35 AM
69HO43's Avatar
Yup.
Old Jan 25, 2025 | 03:57 AM
69HO43's Avatar
Here's where the factory was suppposed to put the emblems. I enhanced the dimensions to make them easier to read.
Old Jan 25, 2025 | 08:52 PM
Thank you!
Old Jan 27, 2025 | 09:48 PM
This parking brake has been a challenge to say the least. Finally got the old front cable out. It was rusted beyond movability for quite some time now.
Got the new one in tonight, cables connected underneath, and we have a working e-brake!
Also got the dent hammered out of the trunk spare area, and started touching up the underbody with some red oxide primer.
Old Jan 28, 2025 | 05:18 AM
  #31
It's looking like your rear frame rails are in decent shape, a huge plus for the car. Also, Waldron's exhaust is now reproducing a correct-style exhaust for the 79's. Their stuff is EXPENSIVE but its on the money. I have on my 79 H/O an Imposter one-in-two-out muffler from them. It's a great muffler, no cabin drone with just a hint of growl at highway speeds, really nice. I used a Walker Cat plus Walker intermediate & tail pipes but not sure if any of that is available anymore, I bought it long ago and stored it until it was installed about 5 years ago. .
Old Jan 29, 2025 | 03:33 AM
  #32
old80cs's Avatar
If you aren't going concourse correct on the exhaust, Pypes makes a set up in 2.5" side exit with choice of mufflers.
https://www.pypesexhaust.com/product...anel?sku=SGG50
Old Feb 6, 2025 | 09:37 PM
  #33
Not too much progress of late but did get the horn figured out.
A new relay (those require some acrobatics to install)...
And replaced the missing horn button, now we've got power to the two horns. FYI, the pin isn't long enough to ground the horn so I had to add a 1/4" or so of threaded rod to the horn cam cylinder.
Old Feb 7, 2025 | 09:27 PM
  #34
FStanley's Avatar
like others have noticed, get rid of that muffler ASAP had a friend who had a one like it the way it dumps out.. , he damn near died because of carbon monoxide while ideling at a drive in....
Old Feb 9, 2025 | 07:58 PM
  #35
Thanks for the tips on exhaust system...is that the original design?
got the backseat removed today and LH seat belts out. Have come up pretty empty on seat belt replacements, do you guys have any recommendations for that?
Old Feb 9, 2025 | 09:07 PM
  #36
You are doing God's work. Keep it up.
Old Feb 10, 2025 | 04:51 AM
  #37
Rear floorboards look pretty good, a huge plus, that saves you alot of work. I had to deal with some rot in my blue Calais years ago in those spots. not fun, working with rust never is.
Old Feb 10, 2025 | 08:07 AM
  #38
GN1220's Avatar
Looks like you're just missing the tail pipe.
Old Feb 13, 2025 | 09:19 PM
  #39
Rummaging around a box of parts that came with car, I found some original rally gauge components, including the connector plug for the dash instrument panel and oil pressure sender! Between that, and BC79's encouragement, I'm going to break this gauge set down and see if I can get it restored and working again. Wiring is a mess with the Dakota Digital unit behind the dash but I'll try and figure things out from there.
Old Feb 18, 2025 | 09:20 PM
  #40
Taking a break from the gauges till I get some parts. Meantime removed the rear bumper to touch it up a bit. Nice hitch huh? Rear frame rails in pretty decent shape, hitch is welded to rear frame and bumper inserts, looks like it's staying.
