Ram Air scoops only ?
Old Mar 25, 2021 | 02:44 PM
Jeff Stout's Avatar
Does a company make the scoops so as to graft onto a 68 hood. I thinking of buying a glass hood and install the ram air scoops but do not want to buy a fiberglass ram air hood and cut up. Feasible?
Old Mar 29, 2021 | 01:09 PM
Miles71's Avatar
Part Number: 69HO
1969 Hurst/Olds Hood Scoop
http://www.fusickautomotiveproducts.com/Aboutus.asp
This company sells the HO scoop
Old Mar 29, 2021 | 01:40 PM
70W-32's Avatar
Check with Rocket Racing, they sell Glastek, who makes a 68 hood(pin-on) with the 70 W30 scoops and an airbox to seal to the carb. If thats what you had in mind.
Old Mar 30, 2021 | 10:41 AM
ajr2820's Avatar
Originally Posted by Miles71
Part Number: 69HO
Do these fit on anything other than a 69 hood?
Old Mar 30, 2021 | 04:58 PM
allyolds68's Avatar
Are you sure? I know Thornton made a one-off 68 hood with 70 style OAI. As far as I know, no one else does.... and why would they.... it looks hideous....JMO
https://classicoldsmobile.com/forums...od-68-a-31684/
Old Mar 30, 2021 | 07:36 PM
70W-32's Avatar
Its listed on Rocket Racings website. They also offer the version with the 2" taller scoops to clear the Victor or RR intakes
Old Mar 30, 2021 | 08:02 PM
I think that would look cool with one scoop, pointed, as wide as the grille and leading from the creases on either side and the middle.
stevedot
Apr 1, 2021 05:55 AM
Bpstump1
Apr 6, 2019 02:23 PM
malone-ren-con@att.net
Nov 6, 2014 03:45 PM
