Update progress on 64 "Post" trunk pans
Old Jul 18, 2010 | 05:49 AM
therobski's Avatar
Man this has taken along time to get this far with everything else going on but here are some pictures updating the progress on the restoration of the trunk. I never got involved to this point on body work on any project, that's a BIG part of the reason I believe it's taking along time to update the progress, taking my time asking alot of questions reading other posts on simuliar projects I am basically at the point-semi-final fitting the three floor pieces with sheet metal screws, aligning the body 4 trunk floor braces to each other and the frame. Tons of rust removal, primer, triming pieces. While the whole trunk was cut out I did take the opportunity to completely restore the rear brakes, install new brake lines, shocks and removed the upper control arm-sandblasted them and installed new bushings. I also boxed the rear section of the frame-practice welding!!IMG_0262-1.jpg[IMG]http://i119.photobucket.com/albums/o136/therobski/IMG_0263.jpg[/IMG]
Old Jul 18, 2010 | 05:53 AM
therobski's Avatar
Few more pictures, have one of the floor pans cleaned up and primed, going to do the other one today. It' was 105 yesterday, was out side in the shop for 5 hours, plenty of fans and cold water!!!!IMG_0263.jpgIMG_0269.jpg
Old Jul 18, 2010 | 06:42 AM
olds425's Avatar
Looking good! That is slow work for me, but very rewarding.
Old Jul 30, 2010 | 05:04 PM
therobski's Avatar
another update on Granny's F85 post
Putting in alot of time on the post here are some up dates, please fwwl free to add some advice, I need it!!!IMG_0274.jpgIMG_0270.jpgIMG_0279.jpg
Old Jul 31, 2010 | 02:30 PM
scottieb's Avatar
The method that works well for me is to lay the new section over the old. Using a thin cut off wheel, I cut both pieces at once. This gives me a perfect gap for mig welding. I will weld in just a few tacks to keep the panel in place. I will do one side at a time so the new panel does not fall through. My two cents.
Old Jul 31, 2010 | 06:30 PM
Red71's Avatar
look-n good keep at
therobski
Sep 25, 2020 07:40 PM
jon1957
Body work
16
Nov 2, 2018 09:10 PM
trackz man
Aug 23, 2010 05:18 PM
442garage
Jul 12, 2010 02:33 PM
