Tools required for restoration
#41
If you cut the sail panel area you would need to support the roof this is a lot of work when you can cut out a few inches and cut out the same on the parts car clamp or have a magnet hold your part in place as you weld or you could glue them in (fusion bound ) also if you clean a area up and it just has pin holes instead if cutting a section ( if a few small area ) you can braze the pun holes up and the brass doesn't rust
#45
If it's just a skin don't think you need to go this far
And yes that video summed it up but the saw doesn't work that fast the plasma cutter is tho lol
