SBO Stroker 380 assembly and details
Old May 24, 2014 | 04:21 AM
boese1978's Avatar
After a bit over 2 years of chassis resto / mod ( a before and after pic), time to start down the home stretch. Much thanks to the many helpful folks here. ESPECIALLY Mark ( CutlassEFI)- he has replied to probably "countless" emails from me and replied with expertise- can't wait to hear the cam you ground for me! Anyway, pics and details forthcoming.
Old May 24, 2014 | 04:27 AM
boese1978's Avatar
block
Before- tired. oil burner....What was done-
Block cleaning/baking
Line bored
Over bored to 4.155"
Decked to 0
Cam bearings installed
Old May 24, 2014 | 04:34 AM
boese1978's Avatar
rotating assembly
Original N crank, mains ground .010 under, balanced and indexed.
Stroked to 3.5"
ICON flat top sbc pistons with Scat rods and TRW Rings
Old May 24, 2014 | 05:10 AM
boese1978's Avatar
#1 & #2 are in.
Old May 24, 2014 | 06:28 AM
yankees's Avatar
What did it run u to have crank machined to fit the sbc conn rods?
Old May 25, 2014 | 05:34 AM
boese1978's Avatar
The bill for all the crank work ( balanced, indexed, under ground and stroked) was a bit under 700$
Old May 25, 2014 | 06:22 AM
brownbomber77's Avatar
What's the PN for the Icon pistons you used?
Old May 28, 2014 | 11:28 AM
boese1978's Avatar
http://www.summitracing.com/parts/ue...-030/overview/
Here's a link to Summit and the pistons.
Old Jun 19, 2015 | 08:34 AM
boese1978's Avatar
Getting closer- update and a couple pics
Cam's degreed, valve train geometry figured, camshaft endplay checked....next purchase is the torque converter so I can mate the block to the tranny and install......homestretch if life stays out of the way
Old Jun 19, 2015 | 11:56 AM
chadman's Avatar
You shouldn't run those stock head bolts with aluminum heads. You should use good ARP bolts or studs with hardened washers. Directly from Edelbrock:
Head Bolts or Studs: High quality head studs or head bolts with
hardened washers must be used to prevent galling of the aluminum
bolt bosses.
Old Jun 19, 2015 | 12:52 PM
cutlassefi's Avatar
Looks great but I agree with Chadman, ARP bolts are the only way to go with aluminum heads.
Old Sep 2, 2016 | 02:23 PM
boese1978's Avatar
Update and some pics
About 1/2 way through a Pypes install which is my last step before firing it up after almost exactly 5 years Hoping it happens this Holiday weekend.
Have a safe Labor Day everyone, I'm staying home and avoiding the crush
Old Sep 2, 2016 | 02:59 PM
RetroRanger's Avatar
72 Olds CS
good luck on the start up....any guesstimate of hp and trq?
Old Sep 2, 2016 | 03:40 PM
boese1978's Avatar
Not really, if Mark reads this maybe he can chime in. I just built it for fun and "because" Thanks for the good luck wish!
Div52
May 9, 2014 02:16 PM
DoubleV
Oct 8, 2013 08:14 AM
cutlassefi
Feb 21, 2013 07:51 PM
import extermination
Oct 17, 2011 07:16 PM
