Project Heirloom Olds
Old Apr 16, 2014 | 11:21 AM
dads72's Avatar
Hello Everyone,
I have been a huge fan of the site for a long time now and have finally began the frame off resto. The car was originally purchased by my father in 1972 from his future father-in-law. My parents dated in the car (Joe P has already made a few jokes on that one) and had it until my brother was born.
My father passed away when my brother and I were very young and we started to repurchase the car at that time under mom's supervision . About 12 years later we finally got the PO to sell the car back in exceptionally rough shape.
With little resources at the time we fixed some major rust issues in the quarters and rockers, repainted the car, and added a terrible interior kit. The 350 had never been opened up and has about 140k miles so the car basically sat due to not being able to have it built. It then went into storage during my college years as I bought out my brother and mother's interest in the car.
Fast forward...it's time to do it. I had a body shop apprenticeship for a few years in highschool so I have our main body man and painter supervising the build in an old car dealership by the old shop (got it cheaper than a storage unit).
The frame had been repaired twice and since the teardown began we found two more cracks so I found a vert frame from a '69 Cutlass and had a small amount of straightening done to it before blasting and painting it.
I look forward to keep you all updated!
Old Apr 16, 2014 | 11:32 AM
Oldsmaniac's Avatar
Cool car, cooler history, good luck with it and keep the picts and progress reports coming!
Old Apr 16, 2014 | 11:43 AM
dads72's Avatar
A little more info besides the story....
1972 Cutlass S in Radiant Green with White vynl top with 350 2brl and TH350. The only thing that has been changed on the car mechanically is a mild shift kit added sometimes in the 80's. It has a white and black interior (had and is not residing in the trash with 8 dead mice...seriously don't store your car in a barn) with the split bench seat.
Planned upgrades for the car...
Chassis/Suspension:
There are huge issues with the frame so this is why I am moving to a vert frame in near perfect condition.
The goal of the car is to have a semi-pro touring car that would be comfortable/reliable on long trips but still down plays the 'gutless cutlass' chants some of us got when we were younger.
-Tall GM Spindles (Looking for recommendations here)
-Tubular A-Arms
-Updated Ball Joints
-etc etc
Engine:
-All Olds
-Potentially Edelbrock Heads
-Alum Intake
-4brl Carb
-Light Cam
-Pistons, Rings, Balanced etc.
-Any header recommendations would be great as I have heard horror stories
Trans:
-Its an auto car now and it will be swapped over and I already have some of the parts. I do know about the crank mods that need to occur.
-WHAT WOULD BE A GOOD 5spd TO GO WITH THIS? I have seen a lot of the forums and I want something that is as 'bolt on and hole cut only' as possible
Gears:
-I believe it has high 2.70s in it now but would like to go to the low 3.0-3.40 with posi...I know nothing about 10 bolts so any guidance would be good.
Interior:
-Looking to update to R134 for the AC and am trying to decide whether to go with replacement parts (this is a factory AC car) or the vintage air route.
-I put a full interior kit in the car and it literally started to fall apart after 6 months of light use so I will either be going with Legendary or a leather interior based on the stock covers and door panels.
Paint:
-I love the radiant green so we are going stock.
-The only thing I cant figure out is some old pics of the car which had a two or three line pinstripe that looked like it ran along the top side portion of the fender into the door but at the front of the fender turned down (they did a terrible job of replicating it after it was painted about 10 years ago). Any info hear would be great put I am guessing the striping was just done at the dealership.
Old Apr 17, 2014 | 05:29 AM
Eddie Hansen's Avatar
Cool story, will be following along, I just want to add it costs the same to rebuild a 455 as it does a 350 there are not many issues for the swap if you aren't stuck on originality, there is no replacement for displacement and with possible aluminum heads etc might even be the same weight as a stock 350
Old Apr 17, 2014 | 06:58 AM
dads72's Avatar
Thanks for the reply Eddie. I would love to throw BBO in it but I'm stuck on the original motor. Thanks!
Old Apr 17, 2014 | 02:38 PM
it's all good ben
It's all good Ben, just more issues with putting aluminum heads on a small block ( OK not really a small block but a little shorter block) mine came with a 350 and I have it wrapped up in case I ever sell and someone wants the original motor so I hear you
Old Apr 23, 2014 | 12:08 PM
dads72's Avatar
Progress...
Here are a few updates for you guys following the build. We now have the car completely torn down and will be taking to get blasted next week. Found some rust issues in the trunk and passenger floor pans but no surprises there. It also looks like when the vinyl was replaced they scratched through the paint with one of the clips which turned into a hole big enough for a screwdriver along the windshield...and an exploding battery which caused a fixable core support hole.
Also found the intact build sheet above the tank which was very cool...I will post some pictures when I have them.
Old Apr 23, 2014 | 12:11 PM
dads72's Avatar
Here is my brakes thread that outlines the suspension...trying to get everything ordered this week!
https://classicoldsmobile.com/forums...ch-wheels.html
Old Jun 10, 2014 | 11:22 AM
dads72's Avatar
Hey Everyone - Car is now on the rotisserie and we will be starting sheet metal work shortly.
I saw a link on the site awhile back that talked about a place to get a FULL trunk pan in one piece...could anyone point me in the right direction?
Old Feb 6, 2015 | 09:34 PM
dads72's Avatar
I have been starving the post of pictures so here are a few more from the summer and fall...
Old Feb 6, 2015 | 10:38 PM
Charlie Jones's Avatar
Phantom Phixer
Cool build , I do have a couple of suggestions though if you don't mind.
If you're just going with a mild build , then E-Brock heads are just a waste of money.
A wide ratio (3.40 low) trans with the stock 2.70 rear will give you 4 good dragging gears with 5th as an "overdrive" of sorts.
The factory air is better if it's complete , just new hoses , 134 expansion valve , and a new dryer . Again , Why waste money on vintage air ?
The cost of a genuine leather interior will shock you. And the thing about it is , leather is LESS durable than good vinyl. Just look at a fourty or fifty year old car with leather if you don't believe me . Legendary is the best choice.
Best of luck with saving your "heritage".
Old Feb 7, 2015 | 06:49 AM
That's cool that you were able to team up with Speedway and take your car to the next level with minimal investment. Wish I was that lucky.
Old Feb 9, 2015 | 08:45 AM
dads72's Avatar
Well Eddie you called it...let me know what you think I should look for in a 72 455 block. I started a new thread. https://classicoldsmobile.com/forums...tml#post789269
Old Feb 9, 2015 | 08:47 AM
dads72's Avatar
Haha Eric yea it worked out pretty well. Its not all luck though...lets just say it never hurts to ask...or ask the people who can.
Old Dec 13, 2015 | 04:11 PM
dads72's Avatar
Old Dec 13, 2015 | 05:19 PM
dads72's Avatar
These were taken after we got the shell back from blasting...had to replace the entire floor and trunk pan, inner rockers, etc etc etc.
Old Dec 13, 2015 | 05:22 PM
dads72's Avatar
Taking the chassis back home to meet the shell
Finally...
We used LizzardSkin after replacing the floors throughout the interior and bottom of the car then covered with semi gloss black.
Old Dec 13, 2015 | 05:24 PM
dads72's Avatar
Time to Edge
Radiant Green
Old Dec 13, 2015 | 05:25 PM
dads72's Avatar
Back on the frame and working on gaps...
Muling parts back from a CA work trip...
Old Sep 14, 2016 | 11:41 AM
dads72's Avatar
Old Sep 14, 2016 | 11:49 AM
dads72's Avatar
A few more recent pictures...its coming together...
Old Sep 14, 2016 | 11:51 AM
dads72's Avatar
Old Sep 14, 2016 | 12:04 PM
Oldsmaniac's Avatar
Really REALLY Nice!!
Old Sep 14, 2016 | 01:30 PM
Stunning!!
Amazing work my friend!! Stunning!!
Old Sep 14, 2016 | 04:19 PM
Awesome work, the color just pops.
Old Sep 15, 2016 | 06:44 AM
dads72's Avatar
Thanks guys - I should have some more pics soon...we did some new things with the interior...real walnut instead of the vinyl and a few other things. Stay tuned.
Old Sep 16, 2016 | 09:56 AM
Tease!!!!
Old Sep 22, 2016 | 02:08 PM
dads72's Avatar
So we were finally able to unveil the car to my mom this weekend which was awesome...the surprise worked well. Still have a lot of loose ends that will take a few weeks to sort but here are a few more pictures.
Old Sep 22, 2016 | 02:25 PM
dads72's Avatar
Also...I have a ton of parts I need to get out of. I am willing to make a hell of a deal on this stuff so PM me if interested.
http://lincoln.craigslist.org/pts/5779786459.html
oldstofty
Jun 3, 2019 03:46 PM
Lady72nRob71
Sep 22, 2008 09:38 PM
TX-SX
Aug 8, 2008 01:40 PM
tex70
May 29, 2007 04:43 PM
