Need help with accelerator problem
Old Jun 23, 2019 | 11:56 AM
jeremytharper's Avatar
Hey guys I have a 1972 cutlass that will hesitate when pushing the gas pedal from a stopping point only. When I start to go I can hear the exhaust but give it a second then it wants to go or I push the gas pedal harder. I think it might need a new throttle cable but not sure. The carburetor was rebuilt and starts great in the cold weather and idles great when I’m running the AC so I don’t think it’s the carburetor. Could use some help thanks.
Old Jun 23, 2019 | 12:05 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Your post is hard to understand. "will hesitate when pushing the gas pedal from a stopping point only. When I start to go I can hear the exhaust?? but give it a second then it wants to go or I push the gas pedal harder."
Do you mean when you are taking off from a stop you feel tip-in hesitation?
If you suspect a bad cable unhook it from one end and push pull it by hand. Feel smooth?
If yes then its a carb and/or an ignition adjustment.
Old Jun 23, 2019 | 12:31 PM
Thank you I will give it a try
jhawkthebeast
Jul 27, 2019 01:10 PM
sbaumer2
Jun 12, 2013 08:07 AM
vista cruiser 1
Sep 2, 2012 03:39 PM
yeahbuddy
Apr 4, 2012 09:54 AM
My442
May 2, 2010 04:24 AM
