My Caprice Wagon Build
Old May 31, 2022 | 09:40 PM
BigT500W's Avatar
Box Chevy+Olds Motor
So I bought my caprice wagon in January. It ran like a slug but a semi healthy slug. Started right up every morning and burned her usually quart of oil per day. Ran good up until two weeks ago when the car all of a sudden lost ALL power. Top speed 45mph when flooring it, that’s how bad it was. So I pulled the motor out and am in the process of dropping in a 350. The 350 is bored .030 over with fresh pistons and rods. Has a melling oil pump, witch came with the oil pickup improperly installed, had to fix that and do it right. Also has a missing oil pan bolt hole that someone filled with weld apparently. So after installing pickup properly, witch was holding onto the pump by hopes and dreams, I did my best to seal the oil pan. Now I’m waiting on my Sanderson shorty headers so I can bolt them on and install my dipstick tube in respect to the headers. Motor was far from perfect. But for what it is I think I did good. 1967 Block, seems to be pretty fresh, #6 heads. If she runs and has no major issues then I will call that a win for $500.
So yes. That’s where I’m at. Once the headers show up I’m going to continue on with my journey. Hopefully this goes well. My very first engine swap. Reloading not on experience, just mechanical inclination and YouTube demonstrations. I’m glad to be here and show my journey with you guys. Feel free to drop some input.
Future Plans - electric fans.
electric water pump
Buying another universal 200r4 and getting it rebuilt with all the goodies, then swap it in.
EFI system of some sort.
When I first got the car
Up close of how clean she is
The identifier on the engine. This engine was delivered to me and was supposed to be a 455. These numbers told me differently.
Edelbrock intake
The 307 trash coming out
They ground the pickup tube connection point so it could fit. Them glued it in with silicone. Instead of interference fitting it like your supposed to. I tapped in them tack welded the new one in place too.
Pan had super fine metal shaving in it. Hopefully I can get away with it. In too deep at this point.
Whole rotation assembly looks new.
Old Jun 1, 2022 | 04:10 AM
JohnnyBs68S's Avatar
Welcome to CO. That wagon is in pretty good shape for its age.
When I read that, my first thought was a plugged catalytic converter. When I had one go bad on my '99 Dakota R/T, it barely had enough power to make it up the incline to the dealer's lot to get replaced (under warranty). Hopefully you've confirmed that isn't your problem here.
​​​​​​​Good luck on your swap, you've come to the right place for Olds info.
Old Jun 1, 2022 | 04:20 AM
VC455's Avatar
Barely Registered
Welcome. Nice Caprice.
Even though I love wagons, yours is a standout.
Some granny kept that in great shape for you.
With your mechanical skills, it should last you for a long time.
Old Jun 1, 2022 | 04:42 AM
tnswt's Avatar
'70 4-Speed W Machine
Best of luck to you BigT as you proceed. Looks like a fine wagon....
Old Jun 1, 2022 | 05:36 AM
Looks like a fun project.
Old Jun 1, 2022 | 05:46 AM
BigT500W's Avatar
Hey I forgot to put this in. I guess this was just a piece of good luck. The mechanic told me $700 to put the motor in when he thought I was getting a Chevy. When he found out it was an olds motor he went up to $1300 for reasons I still don’t understand.
Had he not of went up on the price this would of been a loss. Because he would have not taken the pan off and found the improperly installed pickup tube, that was on its way to falling out.
Old Jun 1, 2022 | 08:31 PM
BigT500W's Avatar
Thankyou. Today I swapped the crank pulley. Now with the older water pump, they line up. Now I have to get a power steering pulley press so I can swap pulleys
Old Jun 1, 2022 | 09:03 PM
Great stuff. I’m a wagon driver, too, but another brand. I love the “soccer mom” stealth mode.
Curious that you say it’s a 1967 block when the Olds 350 was introduced in 1968; prior to that the Olds small block was the 330. The 1968-up blocks have a partial VIN on a pad above the #1 cylinder, and you can see the date in that number sequence.
Old Jun 1, 2022 | 09:06 PM
edzolz's Avatar
Curious that you say it’s a 1967 engine when the Olds 350 was introduced in 1968; prior to that the Olds small block was the 330.
The casting number with a big 2 would be a 350.
Old Jun 1, 2022 | 09:22 PM
BigT500W's Avatar
I guess I have my info wrong, need to do more research apparently…
Old Jun 2, 2022 | 01:45 PM
BigT500W's Avatar
I removed the distributor from my old engine to see the cam gear is worn.
what would cause that? How can I avoid this with the new engine?
Old Jun 2, 2022 | 04:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have never seen an excessively worn factory Olds distributor gear. A few of the name brand name replacement HEI come with grease to coat the gear for break in. So it should be available for whatever distributor you are replacing it with. I assume you aren't running the factory 307 CCC carb and distributor? What number is by the #1 and #8 spark plugs on your Olds 350? That was total BS on that shop, an Olds 350 is a bolt in, unlike a sbc 350. Good thing you pulled the pan, yikes! It is a good idea to do pan gasket and main seals, at least 44 years old and who when they were last done.
Old Jun 4, 2022 | 07:03 PM
BigT500W's Avatar
Power Steering Pump
When a power steering pump sits flush up with the bracket, vs having a gap, what does that indicate is missing or wrong? I know it is wrong for two reasons, this power steering pump originally didn’t sit flush, and it now doesn’t line up with the water pump pulley. Any pointers will be greatly appreciated.
Old Jun 5, 2022 | 06:04 AM
There are spacers, on top of the timing tab and between the side bolt near the motor mount. Almost all Oldsmobile V8 accessories use them. Without them, belts don't line up properly. What number heads does your 350 have?
Old Jun 5, 2022 | 06:10 AM
BigT500W's Avatar
There are spacers. Almost all Oldsmobile V8 accessories use them. Without them, belts don't line up properly. What number heads does your 350 have?
this one has a #6 head on it.
Old Jun 5, 2022 | 06:19 AM
That makes it a 1970, the date code pad will confirm. If a factory 4 barrel, it will be close to 10 to 1. Even the 2bbl was around 9 to 1. Unless it was a factory manual, they got the same mild peanut cam used till the mid 80's. Assuming it wasn't rebuilt with the 24cc cast pistons which lower compression a lot. Honestly a mild cam swap and converter swap and dual exhaust will help wake it up more.
Old Jun 5, 2022 | 06:24 AM
BigT500W's Avatar
It came with an edelbrock intake on it. The pistons are brand new and are not flat… Supposedly it came from a Olds 98 originally.
im worried about this power steering pump. Where exactly are these spacers? Can they be bought? I have another pump assemble that doesn’t have the gap, can I stead them from that?
Old Jun 5, 2022 | 07:23 AM
Between the pump and the shouldered stud that attaches the timing tab. Also the large 7/16" spacer that goes between the bracket and engine block on the driver's side of the block. The spacers aren't available new. What is your other power steering pump set up off? Sounds like you have an 8 to 1 350. It will be a mild improvement over the 307. Being fresh will help, it really depends on the parts used in the rebuild.
Old Jun 5, 2022 | 08:01 AM
This thread has pictures of the studs and spacers, as well as screen shots of the assembly manual showing how things go together.
https://classicoldsmobile.com/forums...ll-fit-164693/
Old Jun 5, 2022 | 09:14 AM
BigT500W's Avatar
So it’s only one spacer responsible for the gap between the pump and the bracket?
Old Jun 5, 2022 | 12:05 PM
Notice how it is cockeyed. Unless you get those spacers in place, it will never line up straight. Once in place with the correct studs and bolts in the right place, everything works.
Old Jun 5, 2022 | 08:27 PM
BigT500W's Avatar
You are definitely right. I went to the junkyard and got a whole power steering pump assembly. Took the spacers and missing bolt and It definitely make it slip in place like it had butter on it.
I wish I could run across a smog pump for an Oldsmobile 307. That way I can run my ac.
Old Jun 6, 2022 | 01:11 PM
BigT500W's Avatar
Having trouble finding the right dipstick and tube for my olds 350, with certainty. Every one I try to take from the junkyard breaks.
here’s my plan, wanted to run a universal chrome dipstick. Was gonna install it, pour 5qts into my fully dry engine then mark where full is. Will this work?
Old Jun 6, 2022 | 01:47 PM
You'll want to get your oil filter full of oil before marking the stick w/ a total of 5 quarts in the engine.
Old Jun 6, 2022 | 10:01 PM
Get the Spectre 5727 chrome dipstick and tube. It requires minor filing on the ribbed portion that goes into the block, a very tight fit. I find all the rest of chrome tubes hit inside and fit loosely. It is very easy to break off a dipstick tube in the motor. The only easy way to remove a tube, is pulling the pan ans tapping from underneath.
Old Jun 10, 2022 | 10:48 PM
BigT500W's Avatar
This
dipstick here is no good. Falls right into the hole and is loose as a goose. Anyone have a NOS dipstick?
Old Jun 11, 2022 | 12:35 PM
This
I had the same issue with every other chrome dipstick except the Spectre. Supercars Unlimited and I'm sure others have the tight fitting replacement tubes with matching sticks.
Old Jun 11, 2022 | 12:38 PM
BigT500W's Avatar
Should of just listened to you in the first place. About to order the Spectre
VORTECPRO
Non-Olds Engines
May 21, 2021 08:55 AM
madmax442
Aug 26, 2020 09:04 AM
Orlando 1
Jul 4, 2020 02:14 PM
Mlunsford33
Aug 6, 2019 02:02 PM
2blu442
Jan 26, 2018 02:57 PM
