Help! Asap!! 260 swap with 307 :(
Old January 14th, 2013, 09:19 AM
79Cutlass805's Avatar
So i am doing an engine swap in my 79 cutlass supreme. i previously had a 260 v8 with a 2 barrel qjet. i am in the process of putting in the '85 307 that came out of a delta 88. i noticed that the wire harness is quite different than the one on my 79. im a noob at this but am willing to do what it takes to get my car running. The carb on the 307 used to have a computer, it is the stock 4 barrel qjet. MY MAIN QUESTION IS..will the '85 307 fit in my 79 with the same carb? i dont have much money and cant afford a new carb or intake. what do i do ANY ADVICE WILL HELP!! thank you
79Cutlass805 is offline
Old January 14th, 2013, 09:24 AM
Octania's Avatar
I don't think the computercarb will like running w/o a computer.
How about an older QJet? I have dozens. Mainly cores, but I have so many 1973 350 carbs - 7043250 - that I would sell a pretty good one for cheap.
Octania is offline
Old January 14th, 2013, 09:35 AM
mac61891's Avatar
I agree with Octania, but a little more passionately. The computer carb, might run without the computer, but in the aweful to horrid range. I would recommend a replacement. Also, do you still have the donor 88? I would be interested in the frame brackets for the engine mounts.
mac61891 is offline
Old January 14th, 2013, 11:42 AM
how much would u let it go for? any pics?
Old January 14th, 2013, 11:44 AM
no i dont :/ sorry
Old January 14th, 2013, 12:42 PM
mike's88's Avatar
Make sure you keep the distributor from the 260, it's not on the computer either.
mike's88 is offline
Old January 14th, 2013, 02:07 PM
i did keep the distributor from the 260. what does this mean? can i use the stock carb on the 307 or no?
Old January 14th, 2013, 07:57 PM
Redog's Avatar
No you can't.
After 1981 the disturbtor and carb were computer controlled. Without a computer in the car, it's not going to run well.
Redog is offline
Old January 14th, 2013, 08:15 PM
Eightupman's Avatar
I speak 100% from experince on this. I once swapped a 260 for a 307. And was SORELY disappointed. I know a lot more now than I knew then, and I should have went with a 350 or 403 no questions, hands down. Both of them will polt right into place.
as mentioned, use the distributor from the 260, BUT you may want to consider a recurve kit (basically changing the weights in the distributor) And yes, score that 4bbl carb from Octania.
but again.. unless that 307 was absolutely free and your 260 is blown and you are stuck without a ride..... step away from that swap
Eightupman is offline
Old January 14th, 2013, 08:26 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
A pre 85 307 would have been a nice upgrade, I have owned several. The 85-up 307 swirl port, everyone complains of lack of power. It will be a small upgrade over your 260. If you insist, get the 350 carb, should be about right calibration wise.
olds 307 and 403 is offline
Old January 14th, 2013, 08:49 PM
thanks for the tips guys! really appreciate the help! i will update soon!
Old January 14th, 2013, 09:21 PM
I actually spun a bearing in my 260 and bought the 307 for $500. i didnt know about the computer. i will learn from this and keep moving foward! So i can use a different carb and keep the original intake manifold correct?
Old January 15th, 2013, 10:37 AM
mike's88's Avatar
Correct, as long as it's a pre 81, which Octania has just waiting for you.
mike's88 is offline
Old January 15th, 2013, 04:04 PM
Redog's Avatar
Just keep in mind about the 307,
81-84 307's had 5A heads and could be upgraded with ease, 85-90 307's were choked with AIR tubes and had smaller head ports for emissions. In other words, for crusing, you'll be fine, but for any upgrades in the future, you'll have to change over the the 5A heads, because there is nothing that will match the 7A (0142 casting) heads.
Also, boggie over to Home DEpot and pick up 8 1/4 inch pipe plugs in the plumbing department. Remove those AIR tubes and plug up the holes
Redog is offline
Old January 15th, 2013, 04:25 PM
Eightupman's Avatar
You CAN in fact remove those AIR tubes from the heads...however if you have a local pull a part yard, those 5A heads are still fairly easy to find. While you are at it, score a cheap A4 aluminum intake... also 84 or older 307 motors I beleive. they are RUMORED to be of similar performance to the Edelbrock Performer. I have no data to back this up, but being an aluminum intake in and of it self provides both a weight advantage and a heat dissapation factor that is better than cast iron.
hope that helps a little more.
Old January 15th, 2013, 04:36 PM
thanks guys i will do that! and as of a stock '85 olds 307. what after market carb can i get for less than 300? i am willing to use a older non computer qjet but i cant seem to find one! i need one in working condition!
Old January 15th, 2013, 04:37 PM
my 21st bday is coming and i want my car to be up and running by the 21st of this month!!
Old January 15th, 2013, 07:37 PM
Redog's Avatar
You are correct.
In building an Olds motor, if you are running low on funds, an 81-84 A4 manifold is pretty much the same are the Performer 350 (3111) intake
Redog is offline
Old January 15th, 2013, 08:39 PM
ANOTHER question guys! how hard is it to rebuilt a carb? an older non electronic QJet? i got alot of time on my hands and am fairly good at taking things apart and putting them back together. im driven to learn how to rebuilt it on my own since i dont got much money. HOW HARD IS IT?
Old January 16th, 2013, 04:07 AM
Originally Posted by 79Cutlass805
HOW HARD IS IT?
It's easy.
Just make sure you've got plenty of time, a big, clean place to lay out all the parts (covering a tabletop with white paper will help you not to lose things, and let you make notes next to parts), and a high frustration threshold.
Read through the steps and operation description in the Chassis Service Manual or Rochester QuadraJet Manual once or twice with the carb in front of you first, and you should have no problems.
Basic kits are about $20 at the auto parts store, with another $10 for a float. You can get fancier kits from carb dealers on line for more, if that's your thing, but for a basic 307, I'd say save your money.
MDchanic is offline
Old January 16th, 2013, 05:05 AM
Eightupman's Avatar
Originally Posted by MDchanic
It's easy.
I'd go so far as to say that getting a QJet specific manual is a better option than the service manual. Cliff Ruggles or Doug Roe books are pretty comprehensive and provide some other "tricks of the trade". It only took me using a scrap carb... about 3 times to figure out what not to do.. lol
I don't recommend using the basic part store kits anymore. The Walker kit, while inexpensive and very useable for a first build (Available at O'Rielly's or http://www.walkerproducts.com/produc...r-repair-kits/) it doesn't have ALL of what SHOULD be replaced.
I'm probably going to buy a kit from these guys (Cliff Ruggles) http://www.cliffshighperformance.com/carbkits.html#tab2 before I tear into my next carb build. They offer two kits priced, the stock build kit only $10 more than a parts store kit. Better quality and a few more parts in the box.
Dont forget to buy a new float and choke spring...
John
Old January 16th, 2013, 06:51 AM
I agree, John,, Cliff Ruggles's book is great, but I was trying to save him money .
MDchanic is offline
Old January 16th, 2013, 12:25 PM
Eightupman's Avatar
Understood... but save money now and spend it later when you have to do it again, or spend a little extra now and not have to worry about it for the long haul.
Like I tell my guys about the $99 per set of Pep Boys tires... sure get them, and you will replace them 4 times as more often than a quality $400 set of tires...
xbody
September 18th, 2020 09:03 AM
brownbomber77
November 13th, 2017 07:23 AM
brownbomber77
July 23rd, 2015 06:17 AM
undercar1
August 23rd, 2014 02:43 PM
denale200304
December 17th, 2012 08:48 AM
Quick Reply: Help! Asap!! 260 swap with 307 :(
