Engine knock in 350???
Old Nov 9, 2018 | 12:48 PM
prosperous90's Avatar
Hello all. Going to check out a 71 Cutlass S hardtop that the owner claims has a knock in the engine. Does anyone have any advice on how to determine if it's in the top end or lower? Don't really want a project where the whole engine needs to be rebuilt. Any thoughts on what to look (and listen) for would be most helpful! .
Thanks and have a good weekend!
Old Nov 9, 2018 | 01:03 PM
76olds's Avatar
Hookers under Hood
Knocking could be many things .
If you can, post a video of it running here. Their are usually guys here from all time zones , all over the world here. You will get a better answer to your question that way.
If its a rod you'll know it .
Eric
Old Nov 9, 2018 | 01:04 PM
I will certainly try to do that for sure. Thanks in advance
Old Nov 9, 2018 | 01:37 PM
Oldsmaniac's Avatar
You can pull plug wires one at a time while running and see if it goes away identifying a rod bearing knock.
Old Nov 9, 2018 | 05:10 PM
RetroRanger's Avatar
72 Olds CS
Originally Posted by prosperous90
.....the owner claims has a knock in the engine. .... Don't really want a project where the whole engine needs to be rebuilt. !
sounds like this is not the car for you
Old Nov 9, 2018 | 10:59 PM
Bfg's Avatar
Bfg
I had a knock in my 71 Cutlass and it turned out to be the timing chain slapping because of excessive play from the nylon teeth had worn off the gear. I replaced the gears and chain and solved the problem. I also dropped the oil pan to clean all the plastic fragments from the gear.
Eightbanger
Oct 2, 2016 02:12 PM
FlyingV5150
May 17, 2014 10:32 AM
Joffroi
Apr 7, 2014 05:27 PM
redrubicon
Non-Olds Engines
27
Jun 29, 2012 08:55 AM
TennesseeDelta
Mar 27, 2007 02:01 PM
