Club coupe period correct 442
Old Nov 3, 2021 | 09:19 PM
oldstata's Avatar
Justin
Well this year has been eventful with some once in a life time kinda scores.
well preserved club coupe 442 yes it’s a Fremont build and I know the deal
can’t decide if this will be a back burner while collected hard to find parts or get it running and enjoy a period correct icon.
claim to have purchased in 67 last licensed in Cali September of 1980. Son inherited it in 2011 and wanted it to go to a good home was very hard for him to sell but we worked about a great deal for both sides
found oil change recites from 1972,3,4,5,6,77
With owners name
Found this very cool home built spacer
Great fit headers
Home built dual snorkel
Breather for the dual Snorkel both sides and relocated horns
Old Nov 3, 2021 | 10:01 PM
Well that like a trip back to the late 60s - early 70s. Gotta love the period aftermarket stuff. Very era accurate.👍
Old Nov 3, 2021 | 10:08 PM
Holy crap I am loving that car. Time capsule like people don't know. Is that really a Heathkit/RadioShack tach? Man that car is awesome.
Old Nov 3, 2021 | 10:11 PM
It would be hard to touch or change anything on that car. Early Stewart Warner gauges. All of it. That car is screaming untouched since the late seventies easy. Hence the RadioShack tach!! Score!!!!
Old Nov 4, 2021 | 04:45 AM
jcdynamic88's Avatar
a little like one i built 2 years ago,very cool and rare. btw i have a red club coupe steering wheel.
Old Nov 4, 2021 | 04:53 AM
oldstata's Avatar
Justin
very nice I am digging the two tone!
this one should be black has a repaint from the 70’s
please pm me a price shipped to 84074 it wouldn’t be tell after the holidays but definitely need. One
Old Nov 4, 2021 | 04:54 AM
oldstata's Avatar
Justin
I must be showing my age, but I didn’t even think about the gage set being period correct.
Old Nov 4, 2021 | 05:06 AM
I'd get it cleaned up and mechanically sorted out, and shoot the body primer gray. Then drive it for a while.
Old Nov 4, 2021 | 05:19 AM
NTXOlds's Avatar
Very cool car! You could certainly fully restore it, but I think it would be cool to leave it as is with all of the classic speed parts. I would clean it up, get it running and make it safe and reliable but otherwise leave it as is.
Good luck with the project!
Old Nov 4, 2021 | 01:37 PM
Rallye469's Avatar
Love seeing pics of this car Justin. It’s awesome.
I’d restore it AND possibly keep a few of the vintage speed parts on it.
Great find!
And look, you already found a missing part!
-peter
Old Nov 5, 2021 | 02:57 PM
oldstata's Avatar
Justin
Rear 442 emblem holes filled with bars ans center rocket
Old Nov 5, 2021 | 05:31 PM
oldstata's Avatar
Justin
Pulled all the plugs out some atf and pb blaster mix in all the cylinders didn’t take much to turn engine over crank by and for amount 30 min and added oil in between full rotation changing oil tomorrow and going to spin engine with the air gun for a few and drain oil and inspect. Cut open old oil filter and new let’s hope for the best
Old Nov 5, 2021 | 09:07 PM
Sugar Bear's Avatar
Spin the engine with an air gun?
Old Nov 5, 2021 | 09:21 PM
oldstata's Avatar
Justin
I was so excited I didn’t proof read or make any sense, that should be spin the oil pump with a drill.
Old Nov 5, 2021 | 09:34 PM
v8al's Avatar
Registered Olds Owner
That's the oldest MSD box I have ever seen!
Any idea what gears are in that 12 bolt?
Also after spinning the oil pump with the drill, rotate the crank and then spin the pump again. Repeat this cycle a couple of times.
Old Nov 6, 2021 | 07:10 PM
oldstata's Avatar
Justin
A friend helped me do this if we did it right we believe 3:55 posi
Old Nov 6, 2021 | 07:20 PM
Rallye469's Avatar
There’s a too letter code on the rear side of the passenger side axle type that will tell you your gears.
-peter
Old Nov 6, 2021 | 07:32 PM
oldstata's Avatar
Justin
-peter
wasn’t sure if it was in the same spot for a 12 bolt chevy and wanted to check with all the performance goodies anything was possible for this thing
Old Nov 12, 2021 | 09:30 AM
oldstata's Avatar
Justin
Well made alittle progress got it in the garage and installed some ss1 wheels, removed front and rear seat hoping to find a build sheet with no luck.
this thing is pretty solid I have to say it’s truly just mostly surface rust with no major body damage that I can see. I cleaned out fuel tank. Tank looks like it’s been dropped recently with new rubber fuel lines and rubber brake lines..
removed distributor changed oil and filter and ran oil pump with my drill. Installed distributor dropped a little fuel down carb and she fired up.
going to run off a fuel can to see if there is anything odd. This weekend.
Old Nov 14, 2021 | 07:47 AM
oldstata's Avatar
Justin
What year do you think this battery maybe?
Old Nov 14, 2021 | 08:25 AM
2blu442's Avatar
Justin, I looked at the pictures and a couple thoughts hit me. That didn't look like a factory bellhousing but an aftermarket scatterproof one. Then the rear end, is that a chevy 12 bolt? You might want to get the casting numbers off the pumpkin to key out what it originally came in.
Old Nov 14, 2021 | 09:24 AM
oldstata's Avatar
Justin
yes, trans and rear end are not correct to the car.
I haven’t called the guy yet to ask if his uncle might know what happen to the original but my guess is the Muncie trans bell housing broke and maybe took a ear off as well. It has a bog Warner 4 speed. Or maybe it was a 3 speed car and it would make it even rarer.
I am wondering if the heat shifter is original as well I know some came with it. But not sure if it’s the correct one either
Old Nov 14, 2021 | 10:28 AM
oldstata's Avatar
Justin
Old Nov 14, 2021 | 10:30 AM
oldstata's Avatar
Justin
Edited
CK = 3:07 positrac metallic brakes 09= September 10= 10th day B = buffalo NY plant
3859140N is A body 65/66 chevelle
Old Dec 4, 2021 | 04:08 PM
oldstata's Avatar
Justin
Some light clean up still need to do the rest of the car really digging the patina
Old Dec 4, 2021 | 05:47 PM
Rallye469's Avatar
Hit that trunk lid with WD40 and a Scott brute pad!
It will clean up.
-peter
Old Dec 4, 2021 | 05:57 PM
oldstata's Avatar
Justin
It will clean up.
-peter
that was the plan
Old Dec 5, 2021 | 02:46 PM
oldstata's Avatar
Justin
Old Dec 5, 2021 | 04:57 PM
therobski's Avatar
Gotda love those A body "post cars"
Old Dec 5, 2021 | 04:59 PM
oldstata's Avatar
Justin
sure do, I love the rust free ones even more!
I know you can relate.
Old Jan 8, 2022 | 05:28 PM
  #31
oldstata's Avatar
Justin
Picked up a few parts recently can’t wait for spring and really get going on this.
Old Jan 8, 2022 | 07:37 PM
  #32
Looking at all your nice pictures tells me that car was set up for racing.
Old Jan 8, 2022 | 07:47 PM
  #33
oldstata's Avatar
Justin
yes very cool vintage performance. The family history on this thing is amazing. Brothers both had their cars and were constantly racing each other
I hope the seller gets back to me. I asked some questions that he was going to ask his uncle about the car.
Old Jan 10, 2022 | 10:27 AM
  #34
08-141 K43727's Avatar
Awesome.... though I am not sure how you stand to live with yourself looking at those oldsmobiles and mountains all the time.... lol.
Keep us posted!
Old Jan 28, 2022 | 06:17 PM
  #35
oldstata's Avatar
Justin
Original paint under the tail lights. I am super surprised they didn’t remove them for the full paint job that was done.
also replaced the tail light lens and bar that was broke.
still need to find a oem/patina rear 442 emblem
pulling engine to go through it going to put a 455 in for the summer went through brakes and all rubber lines fuel/brake have been replaced
Old Jan 28, 2022 | 07:47 PM
  #36
Tj Pal's Avatar
Really like those 64-65 cars. Have that old school look to me. Probably because I’ll be 70 tomorrow! Lol
Old Jan 29, 2022 | 10:42 AM
  #37
TK-65's Avatar
I have some original emblems Justin.
Old Jan 29, 2022 | 02:41 PM
  #38
Rallye469's Avatar
Looking good Justin!
What's it like seeing that black paint for the first time?
That will be badass!
-peter
Old Mar 3, 2022 | 11:35 AM
  #39
oldstata's Avatar
Justin
Not
Not true n98 but will be just as cool run the stock black up front with dog dish all around
Old Mar 3, 2022 | 06:35 PM
  #40
Anderson's Avatar
Originally Posted by oldstata
Not
those wheels are perfect
