Body/Paint Quotes
Body/Paint Quotes
Hey fellas, I have decided to make a leap forward and take my car to a shop for body work and paint prep and finally paint. I was wondering what I should expect to pay for each of these if anyone had any ideas. I got some rust repair that needs to be done (which I know is ambiguous and hard to guess cost) but basically rocker panels need some love, fenders need lower patches, trunk needs welded in and I got some wrinkles in the doors from a previous accident. How much should prep and paint work cost? I am not looking for a show car, but a better-than-new modern paintjob, most likely an OEM color from GM or something. Any thoughts or other questions I could answer to give me a good basic quote? Never done this before and I am currently trying to save up some money to get this all done in one shot. Thanks guys!
There have been a few threads on this .
It really depends on the shop and what you want and how bad the car is really . my guess would be between 6k -10k paint alone these days can range from 1000-4000 for paint alone not even on the car well this is all clear coat too
Several members have talked to a few shops and worked out deals for cheaper labor cost to work on them in there slow times . I have seen good and bad comments on this
https://classicoldsmobile.com/forums...t-painjob.html
Here is some of the damage besides the rocker panels needing replaced. Already had the roof replaced. Trunk is cut out, but new panels not in place. Rear bottom of one quarter looks like it may be displaced a bit (3"). Trunk extensions will need replacing most likely and a hammer taken to the inner quarter well.
What's a good hourly rate?
Wow, after looking at the pic's, I would look for different sheet metal or a doner car also. The shops will rake you for all of that to be done right. I do all of my own body work and paint and that would be quite a challenge to just repair the panels as is. Of course there will be more once you get into them and underneath. Good luck with your project.
Mine is in the body jail right now. The shop labor,rate,is 75.oo per hr. I had estimates from 5 k To 20 k before I settled on this shop. He fell halfway in between. The difference was he wrote me a detailed estimate of what would be included just like a collision shop would do. If he finds something not in the estimate he calls and I go over and look at the problem and there are no questions about was this included or not. Great arrangement. Now if I can just get my car back.
Wow, after looking at the pic's, I would look for different sheet metal or a doner car also. The shops will rake you for all of that to be done right. I do all of my own body work and paint and that would be quite a challenge to just repair the panels as is. Of course there will be more once you get into them and underneath. God luck with your project.
Might just have to try and work this through myself then :/ was hoping for no more than 14K...
Yes, you could save a lot of money doing a lot of the dirty work yourself. Most body shops hate working with rust. Do you have a friend that knows how to weld or someone who can give you a few pointers to learn yourself? It's not hard, and you can use some of the old junk panels to practice on. Just a thought.
Well, I moved from Vegas to Tucson, with all my good bodywork friends in Vegas. I tried taking to a shop, offered them $100 JUST to VISIT my house nearby and ask them to point out what I needed to do on the car (cut versus save, etc) but they never called to make a time even though I asked for just 30 minutes. Apparently my money wasn't good enough. Any shop I have called hasn't called back. So I have been having to teach myself pretty much.
Oldsguy
October 15th, 2009 08:10 PM
