Belgian 1974 Delta 88 Royale convertible
Old Sep 16, 2015 | 01:35 PM
KetsMcLets's Avatar
Hi all, I introduced myself last year when I bought my '74 Delta and last saturday I started the (part) restauration.
I started with removing the top, it was full of holes (big ones) and didn't open anymore.. It quickly was clear the switch was at fault and this was fixed. I then removed the hardened vinyl and lowered the frame.
Then I removed the interior, there was half a garbagebag of junk that came out! and a pile of peepshow lighters
I then removed everything from the backside, the bottom of the boot was almost completely gone!!
This is how she sits at the moment waiting for my next visit
This doesn't look right!! Has anyone got a picture of the Original bracket that holds the topmotor, so I can fabricate something! Or beter yet has anyone got a '74 Delta 88 convertible that I can buy parts from!!??
That's it for now, I started this topic because I know there'll be questions regarding the car that I can't answer.. For now everything went very well though..knock on wood!
Old Sep 16, 2015 | 02:43 PM
The bracket is attached to the car bulkhead with the same rubber bumpers that are used for the A-body convertible top pump, but there is no harm in using nuts, bolts, and spacers, either - it just doesn't isolate the sound of the motor as well.
Old Sep 19, 2015 | 10:39 AM
KetsMcLets's Avatar
Ok thanks for that picture, it's quite helpful! Now I can fabricate a bracket and now I know where all the relays are originaly..
Yesterday I got on with the teardown and it's pretty much finished now and will be off to the welder next week!
Some pictures:
found plenty of rust on the inside too
The boot was really incredible..layer after layer of bodge reparations by the previous owner. This is getting quite a pattern on this car.
This is how she now sits, waiting for me to bring her to a qualified welder in the Netherlands. He called it "a challenge"
Old Sep 19, 2015 | 10:41 AM
My relays aren't original - I set them up to replace the poorly designed original.
Old Sep 19, 2015 | 10:48 AM
KetsMcLets's Avatar
I have a problem though.. I wanted to drive her outside but she wouldn't start! She allways started very good but now suddenly nothing. I thought maybe I pulled some wires per accident or something but I have ignition on every cilinder and gasoline pumping at the carburettor!
The problem seems to be in the carburettor itself? When I pour a little bit of gasoline directly into the carb it comes alive but dies as soon as the gasoline is gone..the same with a spraycan of starthelper (don't know the english name)
The choke is electric and I've manually altered the position but this seems to have no effect..
Any ideas anyone??
A huge challenge. Getting parts or shipping to the Netherlands is also hugely expensive. Is the rust out something that might be better repaired with donor parts/sheet metal from a parts car in the dry west US?
Old Sep 19, 2015 | 10:50 AM
Sounds like the float in the carb is stuck. Try tapping on the float bowl and see if that un sticks it. Sounds like it needs an overhaul.
KetsMcLets's Avatar
Okay thanks! Mine aren't either I'd think, the design looks much newer than the other relays on the car
Old Sep 19, 2015 | 10:57 AM
KetsMcLets's Avatar
Yes shipping is quite expensive and then there's the additional taxes too I have been looking for donor parts for a year now to no avail so I just got me a decent welder who can replicate them, costs a lot but so does shipping huge body panels from the USA
Thanks! I'll try that tomorrow, hope this works.. It was going to get overhauled anyway but it just needed to work a few more weeks while at the welders so he can move it around if needed. But if that's not possible I will take it off and rebuild it in the meantime..
Thank you for the reply!
Old Sep 19, 2015 | 10:59 AM
KetsMcLets's Avatar
this is the carb, it sure looks like it can use an overhaul
Old Sep 19, 2015 | 11:04 AM
Or maybe just get a new one. That looks like a frankencarb!
Old Sep 19, 2015 | 11:08 AM
KetsMcLets's Avatar
Hah yeah I know it's bad.. I was thinking of getting a Q-jet as someone previously mentioned on here but for now the money is going to the more urgent matters like the body repairs and a new roof etc.. Although this may be urgent too
Old Sep 19, 2015 | 11:15 AM
Used Qjet and rebuild kit is not that expensive, at least here. As you say though, deal with the priorities and solve the most important ones first. The welder can put the car on wheel dolleys if he needs to move it around in his shop.
Old Sep 19, 2015 | 11:18 AM
Consider a hole in the fuel line of the gas tank, under the trunk floor, which could have been disturbed as you cleaned off the trunk floor, causing it to open up slightly.
Old Sep 19, 2015 | 11:22 AM
Wouldn't that be kind of obvious with fuel leaking or smell there?
Old Sep 19, 2015 | 11:25 AM
KetsMcLets's Avatar
That could've been possible as there was quite some damage in the boot and i needed to clean that mess up But I have also disconnected the fuel feed on the carb into a jar and it spits more that enough gasoline for it to run so the pump is also fine..
Old Sep 19, 2015 | 11:30 AM
If it's pumping fuel it's likely the stuck float.
Old Sep 19, 2015 | 11:36 AM
KetsMcLets's Avatar
I'll get a little hammer tomorrow (over here it's 08:30pm atm) and tap it a bit, I guess the float reservoir is right next to the fuel inlet on the left side?
Old Sep 19, 2015 | 12:02 PM
Might be 2 floats on that carb, depending on model. Tap both left and right sides
Old Sep 19, 2015 | 01:00 PM
That open port on the drivers side of the carb needs to be plugged like the one on right.
Old Sep 19, 2015 | 01:32 PM
KetsMcLets's Avatar
Yes! I noticed that open port, there was actually a wee little bit of rubber on there when examinating the carb earlier on but it didn't led me to believe that it was completely blocked of before, that's how small the leftover rubber was. So maybe the rest just fell off somewhere? Could this prevent the carb from functioning properly, even so it wouldn't start??
Tnx!!
edit: I think I might see it on the picture laying right below the port??!! doh!
Old Sep 19, 2015 | 01:38 PM
One of those 2 ports is usually connected to the vacuum advance on the distributor. Any vacuum leak can hinder starting.
Old Sep 19, 2015 | 01:45 PM
Usually not. Just needs to be a pinhole.
Old Sep 21, 2015 | 09:25 AM
KetsMcLets's Avatar
Haven't been to the garage so not had a chance to check those things but I have another question: I took a towing hook of the car and won't be needing it anymore so i'm selling it but does this now also fit other frames? Would be nice to know when advertising
Old Sep 21, 2015 | 09:28 AM
A photo would be helpful.
Fullsize (B- and C-body) cars from 1971 to 1976 had the same rear frame section, but there were differences in their rear bumpers, so depending on where the hitch attaches, it may or may not fit Chebby Impala /Caprice, Poncho GrandVille / Catalina, and Buick Electra / LeSabre.
Old Sep 21, 2015 | 10:48 AM
You mean there is a market for trailer hitches in Belgium? I wouldn't have thought so, especially with these land yachts. I don't think many can afford the price of fuel to run those cars. Especially at 1.45€/L!
Old Sep 21, 2015 | 11:10 AM
KetsMcLets's Avatar
This is the one picture I have, not in the photo but there are also 2 brackets on the outside where it attaches to the frame itself:
Over here all USA car/big engine cars run on LPG or LPI..consumption goes up a little but it's 3 times cheaper than gasoline.
If there's a market for I don't know but the ads are free and as long as I can store it I'll advertise it Next stop is the recycling plant..
Old Sep 21, 2015 | 11:18 AM
That looks like a European hitch - in the US, hitches do not curve as they rise up to the ball, they come straight out, and the ball is a separate part that is bolted on.
I suspect that that hitch was custom-made after the car arrived in Europe.
I would try to give it to anyone you can find with a 1971-'76 GM B- or C-body.
It looks like it attaches to the common frame members, and not to the rear bumper, so it will probably fit. If not, they can probably modify it if they need to.
Old Sep 21, 2015 | 12:03 PM
KetsMcLets's Avatar
Okay, thanks for the info man!!
Old Sep 21, 2015 | 12:44 PM
76 Regency's Avatar
Here is someone parting out your exact same car. I believe he's a member on here if I remember right.
http://www.ebay.com/itm/1974-oldsmob...031c17&vxp=mtr
Old Sep 22, 2015 | 01:39 PM
  #31
KetsMcLets's Avatar
I contacted the good man..now waiting for an answer. I still need little things from a donor car like the door catches and stuff..
I blocked up the vacuum line at the carb, I have an MSD ignition kit so no vacuum line needed I guess? I also tapped the 2 float reservoirs with a little hammer and tried starting..once the chambers were filled up again it started rightaway!
Thanks guys!!
Old Sep 23, 2015 | 09:07 AM
  #32
KetsMcLets's Avatar
On a sidenote: eventually I'm going to want to put in a decent soundsystem, doesn't have to be real loud but I want the quality to be good for when cruising! Would this fit my car and has anyone got any expercience from them? Just browsing around for later on..
http://www.classiccarstereos.com/pro...DS-31-630.html
Old Sep 23, 2015 | 09:48 AM
  #33
76 Regency's Avatar
I've never used one of those radios but I'm sure they're pretty decent simply because of the modern technology.
Here is what I use in my cars along with the stock stereos https://rediscoveradio.com/
I love these because I'm a stickler for keeping the original look and feel in my cars and these things do just that and they work GREAT. I have them in both of my cars and the installation is a breeze. The sound is great as long as your stock stereo is good working order and you have a decent set of speakers.
Old Sep 23, 2015 | 10:27 AM
  #34
KetsMcLets's Avatar
That looks great too, even easier install 😁. I also want to keep the stock look but I greatly appreciate the usb and bluetooth functions too 😉. I just came to the garage to take a look and it really looks like it'll fit just fine!! Thats for later on though but it's great to know that I can route all the wiring for the amp and speakers to the original position now the carpet is gone, instead of later on having to take it apart again 😀.
Old Sep 23, 2015 | 04:30 PM
  #35
cus's Avatar
cus
Before you get the welder/panel beater, get those rusty areas sandblasted,
do your whole floor etc, it will expose plenty of holes, but get them
plugged while you have the opportunity,
regards, Cus
Old Sep 25, 2015 | 12:15 PM
  #36
KetsMcLets's Avatar
Too late..I borrowed a towtruck from work yesterday and took her to the welder in another country: the Netherlands! It's actually only 50 km's from my home
Now it's the waiting game for the Olds..on with some other projects..
Old Sep 25, 2015 | 12:18 PM
  #37
Cool! You work for an auto rescue company?
Old Sep 25, 2015 | 12:44 PM
  #38
KetsMcLets's Avatar
I put up billboards as a job but after hours I have a car rescue watch yes..one week on and one week off. Keeps things a little bit interesting 😀 that's actually the smallest lorry we have though ☺
Old Sep 30, 2015 | 01:20 PM
  #39
KetsMcLets's Avatar
does anyone know if my towhook will fit a '79 Pontiac Grand Prix???
Old Sep 30, 2015 | 01:45 PM
  #40
If it fits the Delta, I'm sure it will fit the G Prix.
