Alternate rear a/c brace for tall valve covers?
Old Apr 10, 2022 | 06:27 AM
CuttyShark's Avatar
Installed tall valve covers because I put some new roller rockers on but of course the rear bracket won’t fit over top. Has anyone come up with a way to brace the rear of the stock compressor? I’m guessing that leaving off a rear brace is bad for it?
I know there is a new type sadden compressor and brace like the one on my 442 that came with my Vintage Air but I would rather just brace what I have for now. Thoughts?
Old Apr 10, 2022 | 07:37 AM
redoldsman's Avatar
Proud Viet Nam Veteran
It is probably going to take some fabrication. I am sure somebody on here has done it. I don't think there is a pre-made bracket you can buy.
Old Apr 11, 2022 | 08:00 AM
Hammerdrop's Avatar
I have Harland Sharp rockers, and only used thicker gaskets with the stock covers.
Old Apr 11, 2022 | 08:22 AM
VC455's Avatar
Barely Registered
I did something similar. With Harland Sharps I used the shortest adjusting nut I could find and cut the baffles from the inside of the valve cover. The covers fit with standard gaskets.
I used stock Olds breathers on both valve covers and sourced the PCV from the valley area that had a turkey tray to block most of the oil mist.
Old Apr 11, 2022 | 04:46 PM
RetroRanger's Avatar
72 Olds CS
thats really clean looking Gary
Old Apr 11, 2022 | 07:20 PM
VC455's Avatar
Barely Registered
Thanks, Dean.
My 1970 442 with 4-speed had a similar arrangement. I modified the concept to fit my circumstances.
Gary
Old Apr 12, 2022 | 09:27 AM
bccan's Avatar
I did this with the alternator brace. Though not all that necessary on this engine except to get valve cover on & off with studs, spacer & 2 gaskets. I did basically the same on another engine with tall covers to get basic clearance for the increased height, aggravated by on & off w/ studs.
I found that the alternator mount needs this brace for stability/rigidity so I cut away the obstructing portion.
jimmymtfan19
Mar 19, 2017 01:59 PM
Kyle's 77 Cutlass
Jan 18, 2014 08:47 AM
72cuttys
Jan 4, 2014 05:39 PM
sxsleeper
Jun 19, 2012 07:33 AM
HWYSTR455
Aug 30, 2006 04:40 AM
