72 Post
Old Jan 14, 2020 | 03:10 PM
32redman's Avatar
72 Post
Sorry for the delay. Picked up this 72 Post in July 2019. Here's where I started and
I'm at with the project.
Old Jan 14, 2020 | 03:18 PM
32redman's Avatar
More pics
Solid trunk
Solid floors
Little cancer
Old Jan 14, 2020 | 03:22 PM
tru-blue 442's Avatar
Old School Olds
Looks like a good project Dwight. Let me know if there's anything else you need for it and I will check, Adam.
Old Jan 14, 2020 | 03:38 PM
32redman's Avatar
More pics
Old Jan 14, 2020 | 04:07 PM
RetroRanger's Avatar
72 Olds CS
looks like a good project not much rust except the rear window area.
will you paint it orange again or another color?
what engine is that IIRC the bent fill tube is a1968 thing
Old Jan 15, 2020 | 06:13 AM
32redman's Avatar
Motor was a 69 350. Going with a 455.
Old Jan 15, 2020 | 07:35 AM
4+4+2=10's Avatar
Wow, you are clicking right along on that project. Looks great!
Thanks for posting the "before" pics. This provides some clarity for what paint code 65 (flame orange) should look like. So many versions of that color on restored cars today that it is almost impossible to discern what is really correct.
tc
Old Jan 15, 2020 | 01:09 PM
32redman's Avatar
Few more pics
grooved drums
Couldn't pass on these for $800
Current state waiting on the blocking. One car ahead of me.
Old Jan 15, 2020 | 01:49 PM
joesw31's Avatar
Keep up the good work!
Old Jan 15, 2020 | 02:58 PM
Kolby66's Avatar
Looks great! you have gotten a lot done in 6 months.
Old Jan 16, 2020 | 03:07 PM
oldsmoboogie's Avatar
Solid car, keep up the good work!
Old Jan 16, 2020 | 03:17 PM
Very nice work.
Old Jan 18, 2020 | 04:36 AM
Looking good!
Old Jul 18, 2021 | 10:09 PM
So....?
How's the car coming?
Old Jan 4, 2022 | 08:57 AM
32redman's Avatar
Been awhile figure I'd catch ya'll up. Work got in the way in 2020 minus little projects. 2021 was about the same except for the garage I had built. Back to the grind now.
Thrust Bearing issues. Back on track now.
This was a good day.
Old Jan 4, 2022 | 08:59 AM
32redman's Avatar
Lets get this finished.
Old Jan 4, 2022 | 09:57 AM
72 Olds CS
Yeah that orange looks great! Especially w the black rims and white letter tires!
the tailights and other smalls look nice too. A tip: you can use metal polish like simichrome or similar on the red lens part, it will remove small scuffs and make them look great. This also works on parts like the clear speedo lens and similar ( as if you need more work to do)
next time you see some $800 edlebrocks for bbo send em my way
Old Jan 5, 2022 | 07:26 AM
08-141 K43727's Avatar
Awesome!
Old Jan 5, 2022 | 08:16 AM
Looking great. So is that flame orange?
Old Jan 5, 2022 | 08:45 AM
32redman's Avatar
Yes it is.
Old Jan 5, 2022 | 10:59 AM
BackInTheGame's Avatar
Wow, Looking great! Cool new garage, too! I'm jealous
Old Feb 28, 2022 | 06:12 AM
32redman's Avatar
Few more pieces of the puzzle.
350 I traded for a 455.
455 w E heads I took in trade for the 350.
Clean inside.
Threw some fresh paint on it.
Hopefully I'll get the heart in this weekend.
Old Feb 28, 2022 | 06:16 AM
32redman's Avatar
Trans I picked up. Less than 500 miles. 3000 stall included. $750 I like deals like this.
Horn was a little bent.
I'll fix that up a bit.
I need to invest in a vice. SMDH
Old Mar 1, 2022 | 02:06 AM
cdrod's Avatar
Rodney
I just read through your entire build thread; very impressed that you've accomplished so much so quickly, and the paint looks great. You've done in 3 years what I've been at for nearly 10 - and you built a new garage! I got some questions for you. It looks like the car had disc brakes on the rear when you go it. What was the reason for going back to the drums? I'm a little confused about the motor; you started out with a '69 350, then were building the black engine with the Edelbrock heads, but ended up trading a 350 for a 455. Why didn't you use the Edelbrock heads on the new 455? Maybe I missed something. I'm in Houston, your profile says you're in South Texas - like Brownsville, Corpus, where are you located? What shop did you use for the paint because it turned out great. Can't wait to see you complete it, keep up the good work!
Rodney
Old Mar 11, 2022 | 08:02 AM
Golden Pig's Avatar
For the rear drum: That is a real deal W-27 differential. They only came with drum brakes. Sort of would ruin some of the cool factor of the rear using discs. My best guess.
Old Mar 11, 2022 | 08:29 AM
Loaded68W34's Avatar
Believe it is a standard BOP 10 bolt painted like a W27 with a new W27 cover. Real aluminum housing W27 used a 12 bolt cover. Also, there were more "welds/ attaching points" around the housing attaching it to the axle tubes.
Edit: upon closer inspection of the photos it looks like a chevy 10 bolt based on the fact that the vent tube is in the center housing and not the left axle tube. Later (72 - up) olds may have used this as well. I replaced the axles in both of my 72's and I cant remember for sure where the vent was on them, but I think it was still in the tube on 72. For sure still in the axle tube on 71-down BOP 10 bolt.
Old Mar 11, 2022 | 08:33 AM
Wow where did you come up with a W-27 rear?? Wow!!
Old Mar 11, 2022 | 08:39 AM
See post 26
Here is a real W27 (not mine) for comparison:
Old Mar 11, 2022 | 08:41 AM
Oh gotcha. Thanks.
Old Oct 19, 2023 | 11:57 AM
32redman's Avatar
As usual work and home projects get in the way. Back at it for now.
oldcutlass
Jun 5, 2022 03:01 PM
1970cs
Oct 18, 2016 03:52 AM
btbradley12
Jan 28, 2016 05:22 PM
WolfmanG
Jan 16, 2012 03:26 PM
442much
Aug 9, 2010 09:11 PM
