72 olds 350 block to bellhousing dowel pins
Old May 31, 2026 | 12:23 PM
nj_cutlass72's Avatar
looks like I got a buy a dowel pin to use w stock bellhousing.. appreciate any leads on size and where to order from for a 72 olds 350 block.
Old May 31, 2026 | 01:46 PM
Run to Rund's Avatar
5/8 inch diameter. Amazon, Summit, etc.
Old May 31, 2026 | 02:02 PM
Tri-Carb's Avatar
Do you need a set of offset dowel pins to center the trans input shaft? Here is the tolerance and procedure:
https://www.shiftsst.com/blog/how-to-dial-in-a-bellhousing/241?srsltid=AfmBOoquNyDj3ZSDAYHIhge_K3MhQ9LmX8aiSn w1R6-TsKhsAFueR8TG
o
Old Jun 1, 2026 | 09:23 AM
thanks ordered this one.. admin please move thread to engine or transmission section
Hawghead
Oct 6, 2014 05:35 PM
reesejames
Jul 25, 2010 11:33 AM
ent72olds
May 10, 2010 09:51 AM
reesejames
May 5, 2010 09:49 PM
KRYPTONITE
Feb 4, 2010 10:42 AM
