70 cutlass supreme convertible my first frame off
Old August 11th, 2021, 09:14 PM
  #161
Photoshop God
DewChugr's Avatar
I’m in the same boat as a first timer with this stuff. Same car, just getting started on the trunk floor. But, my son is doing the welding. Good luck
DewChugr is offline
Old August 21st, 2021, 11:07 PM
  #162
tkcutlass's Avatar
More patches
tkcutlass is offline
Old August 21st, 2021, 11:15 PM
  #163
tkcutlass's Avatar
Finishing up the rear portion of the quarter panel.
Old August 21st, 2021, 11:45 PM
  #164
tkcutlass's Avatar
moved on to the front of the quarter hopefully one of the last patches (not happy with a previous owners patch around the wheel well)
After reviewing this article I tried a new technique https://www.musclecarrestorations.co...eet-metal.html.
I need to finish welding but using this technique I did get a nice tight fit.
Old August 22nd, 2021, 06:38 AM
  #165
Phoenix8990's Avatar
Good article, and for your sake I hope this is your last patch! Looking forward to seeing it progress.
Steve
Phoenix8990 is offline
Old August 23rd, 2021, 05:34 PM
  #166
Photoshop God
DewChugr's Avatar
What are you using for a rust converter?
DewChugr is offline
Old August 23rd, 2021, 05:45 PM
  #167
tkcutlass's Avatar
https://www.eastwood.com/eastwood-rust-converter.html
I prefer the aerosol for most areas. a couple of light coats works best, heavy coats of the aerosol never dry and get gooey.
Old September 1st, 2021, 08:12 PM
  #168
tkcutlass's Avatar
I couldn't leave the wheel well with the previous repair and more hidden rot.
Old September 18th, 2021, 08:03 PM
  #169
tkcutlass's Avatar
A few updates got a couple more patches in.
The welder was acting up, after welding an entire patch, I realized the leed got pulled out and gas was no longer making it to the tip.
Pushed the leed back in and the o ring sealed and I was back in business.
The air scrapper worked well removing under coating.
Old September 18th, 2021, 08:09 PM
  #170
tkcutlass's Avatar
The front cowl was hiding more rot.
Old September 19th, 2021, 12:13 AM
  #171
It must just feel great to do all that stuff yourselves. Good on you for following this thru. Oldsmobile on!!!
no1oldsfan is offline
Old September 19th, 2021, 06:44 AM
  #172
Looking good, nice to know there will be no more swiss cheese metal!
Steve
Old September 19th, 2021, 05:17 PM
  #173
tkcutlass's Avatar
It has been a big learning process, each patch seems to get a little easier.
But what made me feel great was stopping by and seeing my 455 painted and getting ready for the Dyno.
I dropped a disposable camera off can't wait for the pics of the build. CVS said two weeks to develop the film. Whatever happened to 1 hr photo?
Old September 27th, 2021, 09:08 PM
  #174
tkcutlass's Avatar
Found a couple more place to patch, but I think I finally got them all.
Still a couple of small holes to deal with.
The cowl brace looked ok to start but was very thin in spots couple taps and it was falling apart so I made new one.
Old September 27th, 2021, 09:48 PM
  #175
tkcutlass's Avatar
Started the clean-up.
Wheel wells are fun I think most of the undercoating ended up all over me.
The HF air scrapper and a wire wheel on my grinder cleaned up the wheel well.
Hit the seam with some rust converter.
Old September 28th, 2021, 04:28 PM
  #176
tkcutlass's Avatar
Before I forget I wanted to post the build
sheet.
Old September 30th, 2021, 04:25 AM
  #177
Tim, great work! I like the way you clamped the patch and cut the patch and old metal in one cut, so it matches. I do it that way also. Now I must ask, aren't you glad you didn't stay with your first rustier body? Wow just imagine what that one would have been like! Carry on doing excellent!!
Greg Rogers is online now
Old September 30th, 2021, 05:06 AM
  #178
Build sheet is a very cool item to have, where was it? And ditto on, glad you didn't take on the 1st rustier one! You really have done an amazing job, looking forward to some body work and primer.
Steve
Old September 30th, 2021, 09:25 AM
  #179
tkcutlass's Avatar
Steve
The previous owner sent me a pic of the sheet.
I may be crazy but I am considering one day bringing back old red.
Old red has much more surface rust, but in the end, I think the new body had just as much or more rot.
BTW Thanks for the kind words Steve, Greg it really helps to keep me motivated.
Old October 1st, 2021, 10:00 PM
  #180
tkcutlass's Avatar
Started filling in the weld seams with "All metal" pretty happy with the results
Old October 2nd, 2021, 11:37 AM
  #181
Let the show begin!!!! Great to see this progress.
Steve
Old October 5th, 2021, 05:23 PM
  #182
tkcutlass's Avatar
Picked up my distributor and carb from Ken at everyday performance.
I am happy with how they turned out.
Old October 7th, 2021, 09:04 PM
  #183
tkcutlass's Avatar
After all the work I am doing I just couldn't let the old seam sealer around the last floor repair stay.
Old October 8th, 2021, 09:58 AM
  #184
72 Olds CS
RetroRanger's Avatar
The carb n dist look really nice.
can you tell us a litle about dist specs?
RetroRanger is offline
Old October 8th, 2021, 10:49 AM
  #185
tkcutlass's Avatar
Those are the specs from the testing and curving on Ken's SUN504 machine.
Old October 8th, 2021, 01:32 PM
  #186
72 Olds CS
Is that an is what is is or did you ask for a total mechanical of 22 ?
Old October 8th, 2021, 09:02 PM
  #187
tkcutlass's Avatar
That is what it is. he said it had a nice curve.
I wouldn't know a nice curve from a slider.
I am sure there are some knowledgeable people here that could elaborate on the curve.
Old October 9th, 2021, 06:33 AM
  #188
72 Olds CS
Thanks both pieces look really nice!
Old October 12th, 2021, 08:38 PM
  #189
tkcutlass's Avatar
Started a little body filler in the deeper areas, getting ready to prime in the next couple of days.
Old October 13th, 2021, 06:47 AM
  #190
1968 442 Convertible
bry593's Avatar
Just saw this thread. Wow, Mr. TK is very determined! No longer an apprentice, his metal shop skills have been greatly enhanced. I can't imagine how many rolls of 2lb he has gone through. Lot of time and sweat!
bry593 is offline
Old October 13th, 2021, 07:41 AM
  #191
tkcutlass's Avatar
Actually not many 2lb rolls maybe 1 or two, early on I switched to 10lb rolls
Old October 15th, 2021, 10:12 PM
  #192
tkcutlass's Avatar
Big progress, my buddy Mike the Bull took himself by the horns and went to town on quarters.
I was going to do the filling after priming. But once we started the push was on to get the filler in a reasonable state to get it in primer.
With the weather turning any day now, there was no time to waste. A few long days and here are the results.
Old October 15th, 2021, 10:35 PM
  #193
tkcutlass's Avatar
Another long day.
Mike the bull was home recovering.
My son stepped up helped with the final cleaning and mixed the paint for me.
I got an Inflatable spray booth (see Inflatable paint booth thread)
I used a fuji spray turbine sprayer
Here are a few pics.
Learned the hard lesson of not getting the gun set right before jumping in. ( many drips and used a lot of primer).
Old October 16th, 2021, 06:49 AM
  #194
72 Olds CS
Nice milestone must feel good to get it one color, even if its primer.
Old October 30th, 2021, 08:48 AM
  #195
tkcutlass's Avatar
started seam sealing.
Old October 30th, 2021, 08:17 PM
  #196
tkcutlass's Avatar
not pretty but hopefully, the seam sealing is done at least on the bottom, with luck may try to paint the bottom tomorrow.
Old October 31st, 2021, 09:09 PM
  #197
tkcutlass's Avatar
Managed to get the bottom painted.
Hopefully, my painting skills will get a lot better before I paint the visible portion
Old November 1st, 2021, 06:48 AM
  #198
Looking good, nice to see you turn the corner on progress and the car really taking form.
Steve
Old November 9th, 2021, 05:35 PM
  #199
tkcutlass's Avatar
Had a nice day to get the floor painted.
Old November 10th, 2021, 05:43 AM
  #200
Must feel good to be at this stage! Keep it up.
Steve
Quick Reply: 70 cutlass supreme convertible my first frame off
