63 starfire ingtion problem
Old Mar 27, 2020 | 05:47 PM
long64's Avatar
I rewired my ignition switch know it stays running only in the starting position dies when you let the key go what did I do anyone I need help.
Old Mar 27, 2020 | 07:37 PM
For some reason your not getting voltage to the coil when the key is in the run position. Double check your wiring from the ignition switch I believe its the yellow wire that connects to the resistance wire to the coil + terminal.
Kyle's77cutlass
May 22, 2019 06:31 PM
bob9822
Jun 18, 2015 02:16 PM
aristellier
Feb 29, 2012 11:45 AM
long 64
Nov 19, 2011 07:03 AM
long 64
Jul 23, 2011 07:33 PM
