1972 Cutlass S Build
Old Nov 3, 2021 | 05:20 PM
oldsmike1972's Avatar
Got the Body on the frame tonight!
Old Nov 3, 2021 | 05:46 PM
RetroRanger's Avatar
72 Olds CS
that looks really nice, i like those rims too...what engine ? any other details ?
Old Nov 3, 2021 | 06:08 PM
Woo Hoo!! That's gotta feel good. What color is that? What else from here?
Old Nov 3, 2021 | 06:33 PM
tkcutlass's Avatar
Nice, what did you paint the dash and inside with?
Old Nov 3, 2021 | 07:06 PM
BackInTheGame's Avatar
Love that color!
Old Nov 3, 2021 | 07:18 PM
Originally Posted by backinthegame
love that color!
x2
Old Nov 4, 2021 | 06:33 AM
Color is Radiant Green, original color for this S. It’s a Basecoat/Clearcoat conversion of the original. White sealer with 5 coats color and 3 coats clear. I’ve got info on the black just not at the moment. The original 350 SBO is rebuilt and balanced. Supposed to arrive this week. It has a hydraulic roller cam, TRW flat tops and worked #5 heads. Using a upgraded TH-350 and a rebuilt rear with 3.42 posi. Wheels are from Year One. Has a 1” drop in front and 1/2 drop in rear. Frame is completely rebuilt along with steering and suspension.
Old Nov 4, 2021 | 12:53 PM
I will be watching your thread. Absolutely love the color. Green looks so good on Oldsmobiles. Can't wait to watch your progress.
Old Nov 10, 2021 | 04:45 PM
For those looking for the detail on the Black, it is SEM Hot Rod Black.
Old Nov 10, 2021 | 04:48 PM
Some frame pics:
Old Nov 11, 2021 | 01:02 AM
cdrod's Avatar
Rodney
Mike:
Is that a Pypes exhaust system? I really like those YearOne rims, just wish they were available in 18" sizes. What are your rim widths and tire sizes?
Rodney
Old Nov 11, 2021 | 03:54 AM
scrappie's Avatar
Very nice!
Old Nov 11, 2021 | 07:19 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Great work!
Old Dec 22, 2021 | 01:28 PM
Will be doing a lot of work on the 72 Cutlass S over the break. Core Support and the doors came in Sunday night. Core Support put together, Latch w/Linkage and Handle installed all torqued to factory standard.
Old Dec 22, 2021 | 02:49 PM
scrappie's Avatar
Looking good!
Old Dec 22, 2021 | 02:51 PM
Looks awfully sweet - nice work.
Old Dec 22, 2021 | 03:34 PM
tkcutlass's Avatar
How/where did run the air lines to get to the air bag connector?
Old Dec 23, 2021 | 02:18 PM
I run it out the top, I measure full suspension travel so the line doesn't go into tension. I use some black zip ties to route the line and then run the line to the interior of the frame. I make sure the line is routed so it can't be compressed.
Old Dec 27, 2021 | 04:01 PM
Pulled the gauges off the shelf. They are going to look great in the Cutlass S.
Old Dec 30, 2021 | 12:51 PM
Cutlass Mike's Avatar
New 72 Cutlass Owner
Very nice build, I too have a 72 in Radiant Green. My core support is in rough shape from the battery. What did you do for the core support? Did you replace it and if you did, where did you get one? I cannot seem to find one. Thanks in advance
Old Jan 5, 2022 | 04:06 PM
Hood and Deck Lid painted, Deck Lid is complete and Hood will have its White Stripes very soon. Wing pics coming soon.
Old Jan 8, 2022 | 02:50 PM
Doing a blacked out grille theme. Have acouple of ribs broken on the RH side. Once I get them back, I'll take some plastic, paint it black and epoxy them in.
I will be polishing the aluminum trim and install to the grilles.
Not sure I'll use the Oldsmobile script, I like the idea of just using the center Rocket logo and keep it simple.
Old Jan 8, 2022 | 05:02 PM
72 Olds CS
The hood and trunk look really nice, radiant isnt my first color choice but wow it looks fantastic on your car. I think it will look good w the black grills.
Old Jan 9, 2022 | 04:58 AM
scrappie's Avatar
Paint job looks real good, nice work on everything
Old Jan 9, 2022 | 10:30 AM
Great thread. Looking so good. Black interior car? Great job. Thanks for sharing with All of us.
Old Jan 9, 2022 | 02:44 PM
As always, Thanks to everyone who take time to comment. I really do appreciate the dialog!
no1oldsfan: It is a white interior. Black dash, black carpet, white buckets & rear seat, white headliner & sail panels. Black console w/Dual Gate. I have the custom gauges sitting in the modded 8-track receiver. I have a Rally Pack. Planning on a Vintage Air AC system and using Siless Sound Deadening and Heat Insulation for the doors, floor, firewall, roof and trunk. All new interior for the most part.
Old Jan 9, 2022 | 03:05 PM
Very nice. I love white interior cars.
I did notice the eight track housing. Great idea and execution.
Old Jan 10, 2022 | 05:03 PM
Ram Air Hood w/Stripes and Clear Coat Polished.
Old Jan 15, 2022 | 04:11 PM
Installing some Siless brand sound deadening and thermal protection. Takes some time but should make the car more comfortable. I'm not done yet but getting it done!
Old Jan 15, 2022 | 04:14 PM
That is brilliant, nice job. I replaced my carpeting last winter and I thought to do exactly what you just did. I was lazy and didn't do it. I should have - I am not worthy. Very nicely done.
Old Jan 16, 2022 | 11:36 AM
  #31
cdrod's Avatar
Rodney
Mike:
Is that the closed cell foam liner? What thickness did you use?
Rodney
Old Jan 16, 2022 | 02:17 PM
  #32
Originally Posted by cdrod
Mike:
Rodney
Hi Rodney,
I got it off of Amazon, it's 157 mil (4mm). It is sound deadener and thermal shield. Yes, it is the closed cell foam.
Regards,
Mike
Old Jan 16, 2022 | 05:40 PM
  #33
Just another data point here.
Back in 1990 or so I debated and chose to replace the tarpaper underlay with the similar stuff. Living in Phoenix where it’s 115 in the summer I can say the heat coming from below is not so much an issue, it’s the sun from above or the ambient air. My feet have never felt hot from heat coming from below, as it did with my friends 1975 Corvette. . And with a convertible the road sound from below is also not an issue, the noise is mostly wind noise from above, and I have not found solution to that yet.
Old Jan 16, 2022 | 07:42 PM
  #34
Old Jan 20, 2022 | 06:08 PM
  #35
Tim75's Avatar
Some call me, Tim
Looks great! Awesome work so far.
Old Jan 28, 2022 | 04:28 PM
  #36
Something fun got delivered today!
Old Jan 28, 2022 | 04:33 PM
  #37
Sweet. Enjoy yourself. If you're going to put the fender/bumper rubber guards on the rear bumper the time to do it is before you mount the bumper.
Old Jan 28, 2022 | 04:44 PM
  #38
Bumper Fillers, Rear, 1970-72 Cutlass, Except Wagon
Old Jan 29, 2022 | 07:11 AM
  #39
72 Olds CS
nice were getting snow delivered today in mass!!
oh your talking about the bumpers . Yeah thats pretty cool too !
Old Jan 31, 2022 | 07:43 AM
  #40
Body to Frame alignment question. Currently, the rear hole is in perfect alignment, fore/aft and cross/car. Checking the front hole, the cross/car is perfect, Ihe body is about 1/3 of the hole diameter forward from the frame hole orientation. Should I set the front hole perfect (moving it rearward) and let the rear float (maintaining a perfect cross/car) or try to center the fore/aft as close as I can front and rear. I'm thinking I should try to do the former rather than the latter as I have fender alignment coming up... Appreciate thoughts especially from those who have done this. Thanks!
