1970 442 W30 Restoration - ap6954
Old Jul 10, 2020 | 04:47 AM
  #121
RR455's Avatar
Originally Posted by Ap6954
0159 so we are about 3700 cars different. They turned some cars out back then. Not sure how many a day but I know it was a lot. That’s why the build quality was, let’s say, not the best! Others on this forum probably know how many Cars a day were made back then.
Reading in here, I thought I saw someone say a hundred cars a day roughly? but keep in mind, the sequential numbers cover some other cars as well. I have a 70 W-30 also that was made 12A. Its 217610 so its right behind these two. Looks like several people asked Santa for the same thing :-)
Old Jul 10, 2020 | 06:09 AM
  #122
My442's Avatar
The production rate was between 55-65 cars per hour depending on the plant.
In 1972, Framingham plant was running at 60 cars per hour, which is 480 cars per 8 hour shift.
The plant ran 2 shifts, so 960 cars per day.
Old Jul 10, 2020 | 06:35 AM
  #123
Ap6954's Avatar
1 car per minute dropping off the end of the line. That’s moving. Bet the paint wasn’t even dry in spots. No wonder we see build “issues” on original cars. You didn’t have much time to fix something if it wasn’t right. Probably a bit of “it’s good enough” mentality at that rate!
Old Jul 10, 2020 | 11:21 AM
  #124
My442's Avatar
These cars were slapped together, with a Minimal Viable Quality plan.
There were production tolerances, which were designed to be generous, allowing most cars to pass.
The cars came off the line and were loaded on to transport carriers or trains.
The frames and under carriages had a dusting of black paint to keep them from rusting before they hit the dealerships.
And, Monday and Friday built cars were the worst.
Old Jul 10, 2020 | 12:06 PM
  #125
Ap6954's Avatar
I wonder how a 1 car per minute production rate compares to a current modern production line with modern robotics? Anyone know?
Old Jul 11, 2020 | 09:47 AM
  #126
rickman's Avatar
I was fortunate enough to visit the BMW plant in Greer SC for a tour a few years ago with my job. I don't remember the actual production rate but looking online, Google states 1500 vehicles per day at that facility. I'm sure the QC dept operates much differently now than 50 years ago.
Old Jul 11, 2020 | 11:57 AM
  #127
Ap6954's Avatar
Just about ready for color.
Bottom of the car is sprayed and the body set back on the chassis. Final gap fitting and panel smoothing just about done. Body should be in Color in a couple weeks. exciting
Original hood fit is real good.
Old Jul 11, 2020 | 12:42 PM
  #128
70W-32's Avatar
From the assembly plants that I have worked in, assembly rate is around 65 vehicles per hour. Framing(Body in white) and paint, operate multiple lines to be able to feed final assembly
Old Jul 11, 2020 | 04:37 PM
  #129
scrappie's Avatar
Thats great! congrats, looks good
Old Jul 12, 2020 | 06:06 AM
  #130
Ap6954's Avatar
So with mostly human hands they put together 60/hr and with full robotics it’s only 5 more. Impressive. But again a robot had repeatability where a human may not. Cool info.
Old Jul 14, 2020 | 11:52 AM
  #131
Ap6954's Avatar
1970 sport mirror glass - OPGI junk
So I needed a replacement glass for my passenger sport mirror. Only place that showed they had it was OPGI. Ordered two in case I needed an extra since they were on back order. Ordered in April. Finally got them and talk about not even close to the right size. The picture below shows the mirror was about 1/4 “ to wide. Sent OPGI feedback and heard nothing but crickets to make it right. So I made a template and brought it to a local glass shop and they ground it down to fit. Came out good but still can’t believe how far off it was. Oh well lesson learned. I do not usually buy from them but figured I would take a chance this time since nobody else listed them for sale. Never again.
Yes the OPGI replacement glass was that far off
New glass after local glass company made the OPGI glass fit with my template.
Old Jul 17, 2020 | 05:04 AM
  #132
RR455's Avatar
Looking forward to seeing this project in color.
I cant thank you guys enough for taking the time to document the process in such detail.
I'm definitely learning a lot about these cars.
Old Aug 11, 2020 | 06:09 PM
  #133
Ap6954's Avatar
Brake Booster Restoration
Got the original Brake Booster and metering bracket back from Brake boosters.com. Looks real good. The folks that bought the business from Steve did a great job. Polished up real smooth and the plating looks excellent. Now all I need is the car back to bolt it on to!
Old Aug 25, 2020 | 02:37 PM
  #134
Ap6954's Avatar
Lower Radiator deflector Restoration
Finished up the lower deflector restoration. The plastic cleaned up real nice. I was able to save the soft “tar paper” for lack of a better word and even the staples to reuse. I like the original look and texture of the tar paper compared to the repop stuff. Cleaned up the staples to bare steel and coated them. Those original staples are thick and tough to bend but they will last another 50 yrs.
Old Aug 26, 2020 | 09:14 AM
  #135
WTHIRTY1's Avatar
Escape From The Ordinary
Thanks looks great, Andy!
Old Sep 4, 2020 | 04:42 AM
  #136
RR455's Avatar
How much longer till paint?
Old Sep 4, 2020 | 06:43 AM
  #137
Ap6954's Avatar
The car is in the spray booth now. Interior dash and package tray is done. Blacks on all the under hood stuff is working now. White and stripes after. Should be soon. Body and paint work takes forever but if you want it done right that’s what it takes. I’ll post photos when I get some more.
Old Sep 5, 2020 | 06:21 AM
  #138
WTHIRTY1's Avatar
Really looking forward to seeing the blue stripes. It’s a pretty blue...different than the others. You have to be getting excited for the color and stripes!
Old Sep 5, 2020 | 06:30 AM
  #139
scrappie's Avatar
X2 on that! Looking forward to paint on mine someday
Old Sep 7, 2020 | 09:28 AM
  #140
Ap6954's Avatar
Pedal assemblies done
Brake and throttle pedal assemblies done. Left the bare steel but coated with a light coat of satin clear to keep from rusting. Left the line where the factory stopped the black paint paint on the brake assembly. Yes I am leaving the old throttle pedal and brake pad on. They are a little worn but the stories they could tell...... a throwback to the cars past.
Old Sep 12, 2020 | 06:29 AM
  #141
Ap6954's Avatar
Fuel tank straps
Small part restoration continues Another benefit of my car being under coated when new and being a southern car. The undercoating while a pain to remove saves the original coatings like the fuel tank strap original galvanizing. I continue to be amazed what Evaporust removes. The undercoating had “stained” the straps a dark color even after removing the undercoating with a heat gun. But soaking them in evaporust took the darkness off and left the nice original galvanizing.
Original galvanizing still looks good
Original M stamping on the straps
Old Sep 12, 2020 | 06:59 AM
  #142
scrappie's Avatar
Thats cool to see!
Old Sep 12, 2020 | 07:13 AM
  #143
WTHIRTY1's Avatar
Your brake booster nuts got me thinking...are you sure they were clear zinc?
Old Sep 12, 2020 | 05:03 PM
  #144
Ap6954's Avatar
Originally Posted by WTHIRTY1
Your brake booster nuts got me thinking...are you sure they were clear zinc? I’m wondering if the two bolts for the Master were clear zinc and the other two nuts were phosphate. Need to check the part numbers and compare.
those nuts were just on the booster when they sent it back after plating. The original nuts are indeed black phosphate as is the bolt from the metering bracket to the metering valve. I think the star washer under the metering valve bolt is clear zinc though.
PIM showing the nut which has the built in washer. I am sure there is a technical name for that style of nut.
My phosphated master cylinder to booster nuts.
Old Sep 17, 2020 | 10:48 AM
  #145
Mark Canfield's Avatar
The P.I.M. that you use are so clear , where can I get the P.I.M. that you use?
Old Sep 17, 2020 | 12:25 PM
  #146
Ap6954's Avatar
i got mine from Paul (user name Hairy Olds in this forum). He has just about the best copy of PIM’s around. I will say the 70 PIM I got from him is a bit clearer than the 69 PIM I have.
Old Sep 17, 2020 | 01:43 PM
  #147
35olds's Avatar
Hairy Olds (Paul). His are the best and clearest.
​​​​​​https://classicoldsmobile.com/forums...dy-pim-131239/
Old Sep 18, 2020 | 01:52 PM
  #148
Thanks for the info. I contacted Harrry Olds and placed an order.
Thanks Again
Old Sep 18, 2020 | 01:55 PM
  #149
Thanks Again
Old Sep 18, 2020 | 02:39 PM
  #150
Hairy Olds's Avatar
Shoveling Snow
Thanks Mark, I think you'll be happy with this manual.
Old Nov 30, 2020 | 09:01 AM
  #151
Ap6954's Avatar
Back from Paint
Picked up the car right before thanksgiving from paint. Paint and stripes came out great. I have to say the blue of the stripe is a unique color. In the sun that porcelain white and light blue looks real bright and airy. The medium blue interior will really set off the color combo. The painter used stencils from Phoenix graphics. They were pretty close but we had to tweak a few spots to get them to the specs. Thanks to the friends on this forum who helped with pictures and drawings of the paint specs so we could get the details right. Especially over the wheel wells where it transitions to the horizontal stripes and stripes ends at the bumpers. Final color sanding and buffing will come after I get the motor in and some of the “over fender” work in case we scuff anything but it’s pretty smooth with just a few spots of trash in the paint that will come out with buffing. Dash and package tray blue came out good with a little “texture”. More pictures to come as we start assembly.
Old Nov 30, 2020 | 10:19 AM
  #152
Diego's Avatar
When there’s a rainstorm and the light afterwards brings out the colors, the blue will glow. It really is an awesome combo.
Old Nov 30, 2020 | 01:41 PM
  #153
scrappie's Avatar
Thats great! the car looks awesome and it is a milestone to get to this point. Congrats!
Old Nov 30, 2020 | 03:57 PM
  #154
RetroRanger's Avatar
72 Olds CS
wow it looks really nice white w blue !!!!
Old Dec 1, 2020 | 04:56 AM
  #155
rob1960's Avatar
Beautiful combo!!! Can't wait to see the finished car!!! Gonna be a stunner!!!
Old Dec 1, 2020 | 05:20 AM
  #156
BackInTheGame's Avatar
That's a Looker!
Old Dec 1, 2020 | 06:14 PM
  #157
scrappie's Avatar
What type and brand of paint?
Old Dec 2, 2020 | 05:33 AM
  #158
442Dude's Avatar
Great job. The car is looking awesome. It's fun to watch them come back to life.
Old Dec 2, 2020 | 08:12 AM
  #159
Jeffs71's Avatar
Absolutely gorgeous
Old Dec 2, 2020 | 08:56 AM
  #160
Ap6954's Avatar
Paint was PPG Deltron. It’s what the painter likes to use. Base coat white. Followed by two coats of clear.
A light scuff. Then the stripe blue. Followed by three more coats of clear. Stripes are under the clear. Some of the purists will not like that but I wanted a slick finish. Personal choice.
