1969 442 Dash - assistance needed
Guy's, Putting the dash back together on my 1969 442. I know somewhere on here there was some good pictures behind the dash- after it was taken out of a car. Cant find through search can someone either direct me the right thread or send some shots? Need to make sure i understand how everthing goes together.
Also need to advice on the steps: the order the parts go back in ( car has air and i took it apart about a year ago)
for example i think i took the gauges out first then lifted out the dash but i saw that maybe i should reinstall with the gauges already mounted in the dash pad. I have a new wiring harness as well.
Just need to advice from someone who's done this previously. Pics below of my current situation.
Thanks, John
John
Thanks, John
John
Made some progress yesterday. Assembled the dash with gauges installed. Going to add the vents so that i can snap the plastic attachment and ductwork in after. Will remember to arrange all the vacuum lines and glovebox liner before i install the heater core box.
I noticed that one of the dash pad studs has a push in fastener-- let me know if theres a correct place to use that as it must have to do with what is reachable when then originally built the car.
Posting the pics of the dash
John
John
OK -- found some items i cant remember how they came out, what they are or where they go---
- I know the grey wire goes on the back of the tac but i don't know where it connects.
- The blue wire was screwed to the firewall - cant figure out what it connects to -- is it factory? There are two plastic loops that hold it on the fire wall--seems like underneath the firewall pad? would it be a line to the console?
- The wire with the metal thing on it - not sure
The plastic clip - not sure
- I have one more wire to add with next post
Otherwise i think i am good to go and will get this dash on next weekend!
Thanks for any help -- John
John, here is a pic of my tic-toc-tac.
Hope it helps. I can't quite remember
but that clip with the 2 screws may be
for the glove box?
Seems there was at least 2 of the pins
attached to the dash that just push into
the fixed metal part of the dash.
for the glove box?
Thanks it looks like that grey wire connects to the small screw on the back of the tac. In your pic its bottom right. The clip is definitely the glove box -- thanks now i remember that part. Not sure i understand what you mean about the two pins.
Best, John
Best, John
Plastic "clip" is the glove box latch catch.
First grey wire should be light for your tach, hooks into another grey wire that supplies power for all the dash lights.
The second wire looks like the ash tray light.
I don't remember any pins that just push into the metal part of the dash. All of the studs on the dash pad are screws on the dash pad side and bolts on the metal side. There are speed nuts (very specific ones, not just ones you can find on the shelf at an auto parts store) that then go on the bolt style end to keep the dash pad tight to the metal part.
This page shows the studs (lower left corner):
Wow, I was wrong (big surprise there). There is one place where the stud is held in place by a clip. Looks like the stud between the speedo and tach/clock pods. No wonder I had such a bitch of a time getting a speed nut on that stud. Mine didn't have that clip there. Damned previous owners
Yes, I've seen the push in stud in a couple different locations, maybe from different years. Here's a 1969 Cutlass and you can see this clip in one of the holes. On this car it was just to the right of the speedometer pod. John
Still cant figure out the grey one with the metal thing on it
The push in stud on my dash pad is to the right of the radio - maybe they put them in different places depending up the manuf plant?
I think i'm going to need some pictures if anyone has taken pics of a dash as they disassembled one. Want to make sure i plug in most of this correctly the first time.
Also is there any type of grease that should be used on the connections to the gauges so that if i need to move things around the connections will come apart without snapping any pins? ( they look fragile)
From a process standpoint--Do you plug in as much as possible and then bolt the dash in or bolt the dash first and then fish the wires to the gauges.
Sorry to ask so many dumb questions but i haven't done one of these before and want to make sure i do it right.
Thanks,
John
Methinks you need a Chassis Service Manual and an Assembly Manual. Go here:
http://wildaboutcarsonline.com/
and sign up for free. Then access the 1969 CSM, AM, and Body Manual, all for free. A wealth of information that you will use over and over again.
Like this:
Thanks Alan-- i see now. took it apart and the bulb also needs replacing. Would of never looked in there..
wow-- this is exactly what i needed-- thanks!
Wire to the tach from the neg post on the coil should also have a wire mesh "shield" around it. shield needs to be grounded on dash inside firewall otherwise will get a lot of static on radio. after passing through firewall, tach feed is suspended from firewall and then goes to coil.
John
Did you put all new correct type [number] bulbs in the holders? No time like the present.
I like to install and remove the dash and all wiring to the fuseblock as an assembly. Much easy. Your two little plastic loops hold the wiring to the dash plastic in the gages area.
I recommend silicone dielectric grease on the pins for the gage pod connectors. Makes dismantling later not only possible but easy, and yes the pins are very fragile. Bad design that thankfully is no longer used anywhere. Ever.
John
Guys - first off thank you for all the help. I don't know where i would be without the support.
Making good progress and shooting to install the dash on saturday.
That being said i have a couple questions:
- The brown tach wire with the 2 amp fuse will hook to my MSD box ( the right side of the box has a port that should work. I want to confirm where on the back of the tach that wire connects. The tach was rebuilt using modern internals and appears sightly different from the version in the assembly manual. ie the two bulbs only have the black plugs that turn in - no grey wires.
See the pic where i have it and let me know if its correct.
- Im going through and marking every wire and there are several i cannot confirm. Most i should be able to work out as i get everything positioned but im sure to have some additional questions.
For those of you that have installed a dash in a 68-69 - a question. Did you plug in the wiring harness to the speedometer before installing the dash or after? i cant tell if the wire is holding me up from getting the dash all the way in...? ( it appears i "could" route the wire for the speedometer around the back of the metal dash structure)
Everything else looks of so far
let me know
Thanks!
let me know
Thanks!
76 Regency
September 19th, 2014 08:06 AM
5998DownUnder
Suspension & Handling
May 28th, 2010 05:45 AM
