Loss of power
Old June 12th, 2014, 04:34 PM
joesw31's Avatar
Loss of power
joesw31 is offline
Old June 12th, 2014, 04:46 PM
Grace Stinespring-Welch's Avatar
ours lost power a while back. i cut the converter off and replaced it with straight pipe, it still runs good.
Grace Stinespring-Welch is offline
Old June 12th, 2014, 04:58 PM
Redog's Avatar
Have you changed the fuel filter?
This doesn't sound like a cat issue
Redog is offline
Old June 14th, 2014, 06:02 AM
jcdynamic88's Avatar
loss of power
did you check fuel pressure after installing the new pump? fuel pressure regulator can bypass fuel back to the tank causing low pressure.if it has a MAF"mass air flow sensor" I have had these go bad wihout causing engine light or codes. a piece of dirt or dust can cause these to read incorrectly, they are very delicate.
jcdynamic88 is offline
bourbon454
April 19th, 2010 07:21 PM
nohn
June 30th, 2008 09:09 AM
2 door cut
August 30th, 2006 07:03 PM
martine
January 3rd, 2004 11:29 AM
martine
August 16th, 2003 07:49 AM
Quick Reply: Loss of power
