"engine check light"
Old May 25, 2006 | 05:38 PM
JACK RYAN's Avatar
I own a 98 Old's Intrigue 3.8. Prior to my state inspection I decided to change the oil , air filter and the PCV valve. The MAP sensor housing came apart when I was removing it from the PCV valve housing. the circuit looked fine so I crazy-glued it back together and the "engine check light" went out and was fine for 2 days, now the "engine check light" is back on. I decided to just break down and replace the MAP today and the "engine check light" still won't go off, any insights? Hope you can help....
Regards,
Paul
Old May 26, 2006 | 05:09 AM
Oldsguy's Avatar
Past Administrator
Disconnect the battery negative cable and let it set for 15 minutes. Then reconnect it, this should force the engine computer to restart from scratch. You may find that the car is a little rough starting or running or the fuel economy may rise for about a tank's worth of gas but that is the computer re-learning all your engine parameters. This may fix it, not a guarantee. Of course, you will also have to reset the clock and all your radio presets.
Old May 26, 2006 | 06:19 AM
JACK RYAN's Avatar
check engine light
Hi Dan,
Thank you for the reply. I did try that already with no results. Could it be a faulty new PCV valve? or maybe a small vacum leak around the PCV housing?
Old May 26, 2006 | 08:21 AM
Oldsguy's Avatar
Past Administrator
yes, it could.
Old Dec 13, 2008 | 10:47 PM
easytobedead's Avatar
Just A BaBy {:
spam?
Old Dec 15, 2008 | 10:57 PM
Redog's Avatar
What code are you throwing?
Old Dec 15, 2008 | 11:26 PM
dan2286's Avatar
Did you put the o-ring back on the pcv valve and the map sensor housing? Did you make sure it is seated right? Also, like reddog said, it would help to know what code it is.
Old Dec 16, 2008 | 03:43 AM
74 Omega's Avatar
Check the date...2 1/2 year old thread...had spam on it yesterday so it was brought back to the top.
Old Dec 28, 2008 | 09:27 PM
dan2286's Avatar
Originally Posted by Kakygoovestokstiz
obtaiigngidpeqpjwell, hi admin adn people nice forum indeed. how's life? hope it's introduce branch
Drugs are bad.
VikingBlue
Sep 20, 2013 12:55 PM
gregorcarp
Oct 16, 2012 03:57 PM
fastflyer
Mar 1, 2011 04:45 AM
sean000
Jan 31, 2007 05:03 PM
