Which carpet is closest to OEM for 72 cutlass
Old Oct 6, 2012 | 11:10 AM
1972 Hurst Olds's Avatar
I want to replace the carpet in my 1972 pacecar I see black is a no brainer for color match but what company is the best and looks original. I read its the 80/20 and I see its two piece. How about the sound deadner package was that also installed when new? Please reply with the best brand I see alot of ACC thanks
Old Oct 6, 2012 | 11:52 AM
Welcome to C.O. Love to see some pics of your HO. Curious, is it one of the 220 sun roof cars?
Just about all the repro 80/20 loop carpets are good nowadays. Only thing the vast majority DON'T come with is the headlight dimmer grommet. So don't throw that out with the old carpet.
Just choose the supplier that's closest and offers the best shipping. These carpets are pre formed and need to be 'steamed' to relax the backing from shipping. Most also come with the jute backing (that you call sound deadener). Sound deadening is also another feature that is put under the carpet/jute, between the rear seat and trunk, and under the firewall padding.
Where are you located? That would assist in recommending more local suppliers
Old Oct 6, 2012 | 12:09 PM
I am in NJ and this car is hardtop no sunroof. It is a genuine hurst but the vinyl roof is long gone and from what I read here it is not easy to get original top material. I have 8 track no computer security system (atleast the keyhole in fender) I will post some pics
Old Oct 6, 2012 | 12:11 PM
Lady72nRob71's Avatar
I used ACC carpet that was ordered from Legendary.
It seemed very close to the original and had the jute stuck to the bottom. I installed a lot of dynamat stuff, so I had to shim some areas with more jute for just the right fit.
Overall, I was very happy with it. Oh - dimmer grommet was included!
Mine set out on the kitchen floor for 5 months, so the wrinkles went away on their own.
Old Oct 6, 2012 | 12:17 PM
I do see a ACC setup on ebay with sound padding (besides the jute ) for about 200 shipped.
Old Oct 6, 2012 | 12:23 PM
joesw31's Avatar
I just changed the carpet in mine, and I got it from Fusick Automotive, and it was ACC carpet. The fit was nice and it had the grommet for the dimmer switch.
Old Oct 6, 2012 | 12:54 PM
Heres a pic
Old Oct 6, 2012 | 01:08 PM
Unfortunately the previous owner went for the cheaper non oem stripe kit. Would it be difficult to remove it and reinstall the correct fade type decals?
Old Oct 6, 2012 | 07:31 PM
Not sure what you mean. The original HO's were decals too and that pic (assume it was camera flash) looks correct to me. Stencils and Stripes makes these kits. Maybe give them an email and ask.
Old Oct 7, 2012 | 09:54 AM
If you look on ebay you will see decal kits that are about three hundred and there is one for seven ninety five. The correct decal kit has fading on the hood and trunk and sides and the cheaper is one steady color. I actually like the cheaper one but it bothers me that it isnt the original design. I will post pics of both so you see the difference. The photo from higher above next to the house is an example of the correct stripe on the trunk
Old Oct 7, 2012 | 10:12 AM
On the 2 pics (I'm guessing yours is the second) I also noticed the decal on fender is not lined up properly at the top of the 'Pace Car" decal.
But the first one is likely a clone - note the improperly positioned HO emblems and the OLDSMOBILE script on the trunk? I wouldn't base my decision on a car that has obvious flaws like that.
Now the fading issue? I'm not sold on that. You know that these decals (I believe they were made by 3M) will fade over time? In order NOT to fade they have to be sealed over with a clear or seam seal that takes the originality away from it. I'd be more inclined to reposition your fender decal and call it good. You have a very striking car there even without the vinyl roof (which is missing on the car in photo 1 too)
Old Oct 7, 2012 | 10:27 AM
When I say fading I don't mean by the sun if you look closely the stripe gets lighter toward the back window because it actually turns into a group of dots rather than the solid color.
Old Oct 7, 2012 | 10:28 AM
Wow I never noticed the decal is high on that one and I also was told trunks with olds on them were at best dealer add-on vehicle to try to keep up with demand.
Old Oct 7, 2012 | 10:45 AM
I just went to Stencils and Stripes. The fade out kit you're talking about is
22521972 1972 - Hurst/Olds Fade Out Decal Set - Gold - Reflective $985.00
I'd call them or email and ask for details if you're serious about replacing the decals. They should also have a guideline on placement. I think that info is also in the 72 Assembly Manual somewhere. I know I've seen it somewhere
milesmonte
Mar 23, 2015 07:31 AM
Warren Seale
Feb 19, 2014 08:23 AM
67442nut
Oct 20, 2013 03:02 PM
defiant1
Mar 4, 2012 01:48 AM
OLDSmobility
Apr 25, 2011 06:54 PM
