68 Cutlass interior into 71/72 Cutlass?
Old Aug 19, 2012 | 08:33 PM
Texas69's Avatar
I know the 68 had a shorter floor console than the 71/72, but would it be a direct bolt-in if you could live with it not being original style?
Likewise, would the bucket seats, rails, and brackets from a 68 Cutlass be a direct bolt-in replacement for a 71/72 Cutlass with a bench seat? I imagine some drilling may be involved, but it should otherwise fit, correct? I understand the styling and seatback tilt would be different between the years.
Old Aug 19, 2012 | 08:37 PM
2blu442's Avatar
I think you could swap the bucket seats, but I'm not sure the floorboard would be similar enough for the console. I know the door panels are too different. John
P.S. rather than drill you can get repop bucket seat studs attached to a strap that can be welded onto the floorboard. That's what the factory used for the inboard seat bolts on each bucket.
Old Aug 19, 2012 | 09:00 PM
The buckets can be swapped but they won't be the correct style for 72 if you can live with that. I don't know why the floor console can't be swapped into a 72. Goodmark Replacement floor panels from 68-72 A body are the same for Olds, Chev, Pontiac and Buick. X2 on welding the bucket mounts instead of drilling.
Old Aug 20, 2012 | 08:15 AM
tru-blue 442's Avatar
Old School Olds
Console mounts are different on 67-69.
You would need the mounts for those years.
I belive there are two, one front, one rear.
These are welded in as well.
Old Aug 20, 2012 | 09:12 AM
arodenhiser's Avatar
STOP call'n it a Chevelle
Are you going from column shift to floor shift? If so, the 67-69 consoles have the Neutral Safety switch in the console, not on the steering column. You would need to get/make a wiring harness to the wires in your dash. The 67-69 console DO NOT have the steering lock rods/hookup that the later ones did. The buckets will bolt in providing you install bucket seat brackets on you floor pans. The mounts are repro-ed and not a hard welding job.
Adam
KDW
Jul 16, 2021 02:39 PM
NTMD8TR
Paint
Sep 17, 2014 09:45 PM
pfergy600
Jan 23, 2014 03:09 PM
olds70supreme
Aug 2, 2010 04:17 PM
69Rman
Mar 16, 2009 05:40 PM
