Cigaret lighter
I am trying to get mine back in...I bought my Olds from my deceased fathers ex-*****, and I found it in the glove box, can't see the wiring that it needs to be plugged into, so I could use any help getting mine back in, but I don't even think that it is all there...how is it held in the dash?
First, unhook the negative battery cable. Then reach up under the dash. The cir lighter is a two piece nested assembly (like those Russian dolls). When you can get ahold of the assembly, try rotating it CCW. You may have to hold the inside part from the front to keep the whole assembly from turning. Oh, if it is hooked up you will want to remove the power wire, should be a normal plug hook-up.
