Cigaret lighter
Old Jul 6, 2011 | 06:01 PM
MyPaceCar's Avatar
Cigaret lighter
Ok, this may sound stupid, but how the hell do you remove the lighter? There has to be a easier way than yanking half the dash apart?
Old Jul 6, 2011 | 06:21 PM
kevin.horton's Avatar
I am trying to get mine back in...I bought my Olds from my deceased fathers ex-*****, and I found it in the glove box, can't see the wiring that it needs to be plugged into, so I could use any help getting mine back in, but I don't even think that it is all there...how is it held in the dash?
Old Jul 6, 2011 | 06:37 PM
starfire's Avatar
First, unhook the negative battery cable. Then reach up under the dash. The cir lighter is a two piece nested assembly (like those Russian dolls). When you can get ahold of the assembly, try rotating it CCW. You may have to hold the inside part from the front to keep the whole assembly from turning. Oh, if it is hooked up you will want to remove the power wire, should be a normal plug hook-up.
Old Jul 6, 2011 | 06:46 PM
MyPaceCar's Avatar
So you have to remove all the floor vents to get your hand up there I take it?
Old Jul 6, 2011 | 07:11 PM
starfire's Avatar
Maybe, it's been too long since I've had a '70. With a 68 you don't have to, but it makes it easier, esp. if you have big hands.
Old Jul 6, 2011 | 07:23 PM
Lady72nRob71's Avatar
On my 72 you can reach your hand and arm up in there. I had to plug my lighter back in the other week. Of course thats if your arm is somewhat skinny.
Old Jul 6, 2011 | 08:15 PM
MyPaceCar's Avatar
Well, I don't have skinny arms, so I have that against me. I will see if I can fit my fat arm behind the dash tomorrow and see what happens. Thanks for the responses!!
Old Jul 7, 2011 | 12:04 AM
oldsguybry's Avatar
NOVICE car nut
thats funny
Old Jul 7, 2011 | 05:09 AM
Keep your cell phone with you in case you get your arm stuck. Almost happened to me...
Old Jul 7, 2011 | 06:50 AM
AZ442's Avatar
Go through the tach or clock hole. 5 screws
Old Jul 7, 2011 | 04:01 PM
MyPaceCar's Avatar
I got it. I pulled down the lower vent, and got my fat arm up there. Damn thing came unplugged.
Old Jul 7, 2011 | 04:08 PM
MyPaceCar's Avatar
Good thing I didn't need to use my phone. Getting out from under the dash was the hard part....HeHe.. Good one Lady72nRob71
Del70
Oct 18, 2010 09:46 AM
tim72
Aug 5, 2010 07:51 AM
Bunser
May 24, 2010 05:47 PM
matt68
Sep 25, 2009 01:43 PM
GOLD72OLDS
Oct 17, 2007 05:21 PM
