A pillar removal
Old May 23, 2011 | 12:23 PM
455man's Avatar
A pillar removal
I want to remove the A pillar covers on the inside of the car to paint. I removed the screw at the top and bottom but it was still tight. Is there something else I'm missing or do I just need to use some muscle? I was afraid of breaking something so I did not put too much into it.
Old May 23, 2011 | 12:34 PM
501Paratrooper's Avatar
You have to remove or loosen the kick panel, sill plate to rempve the pillar molding.
Old May 23, 2011 | 04:26 PM
stan 65 cutlass's Avatar
mine are also screwed on under the windsheild chrome
Old May 23, 2011 | 04:31 PM
Shizzy's Avatar
with the door open look down at the very bottom of the trim piece. Should be a screw there.
Old May 23, 2011 | 04:39 PM
also under fender, if similar to 65
Old May 23, 2011 | 06:26 PM
Shizzy's Avatar
also, if I remember right, mine did need a little nudge to pop loose.
Old May 23, 2011 | 08:51 PM
70Post's Avatar
If these are the '70-72 metal moldings there are only two screws holding each one on....one up high and another you see at the very bottom when the door is open.
You shouldn't need to loosen the kick panel. I removed a set from a '70 a couple weeks ago.
Just remove the two screws and carefully twist, etc. Usually they are stuck at the top. Sometimes there's windshield chaulk touching them and make them stick a bit.
Old May 23, 2011 | 09:39 PM
ah, inside ,
Old May 24, 2011 | 07:13 AM
455man's Avatar
Yeah the inside on my '72. I wanted to make sure there were not clips or anything I did not see. I'll work them loose when I get time this week. Thanks for the help.
Bluevista
Jan 29, 2009 02:56 AM
Bluevista
Apr 22, 2008 05:33 AM
gyu81
Jan 12, 2008 03:39 PM
Pinner
Apr 1, 2007 11:48 AM
perrygil
Mar 15, 2007 08:43 AM
