dash removal
I have a 71 dash and pad,I can't see how they come apart! I think the padding and cover are made right on the plastic dash panel.Does anyone know if it really comes off? Nice start on the project! ---bil
Bill, the panel that holds the headlight switch, heater controls and radio will unbolt from the pad. If you have it out of the car look closely, I think it's small fasteners like sheetmetal screws that hold the two together. John
Supposedly the dash 'pad' is supposed to come off seperate from the rest of the dash or something? At least thats what the manual seemed to suggest. I took it all off in one piece. When GM made this chassis manual, they did not create it with the laymen in mind. Sometimes I was completely guessing on what to remove, and what X or Y even was. They also don't mention how to take off ***** on heater controls etc on most pages where they tell you to do that; i found it by accident
Here's just what you need for $21 plus $6 shipping.
http://cgi.ebay.com/ebaymotors/1972-...sQ5fLiterature
I think your problem might be that the chassis manual is exactly that. Your car's interior is part of the body, and for that you need the Fisher Body Manual for your year. That was a separate manual in those days, and it's about as vital as the chassis manual. Get that, and I think your removal of these parts would no longer be guesswork.
I actually have the fisher body manual, but I believe I leafed through it and did not find any thing on the dash. I could be wrong; but my thought process told me to check there first, and finding nothing, I checked the chassis manual. Because the dash is all about actually removing 'components' like gauges etc. I think it was put into the chassis manual, because the dash is really just a protection layer to keep the electronics and mechanical pieces behind it safe. I appreciate the help though!
-Jimmy
edit: Also, thanks for showing me how to get pictures to work, svnt442
Well, you didn't say that initially, so we can only guess. I have often found that things that I expect to be in the chassis manual turn out to be in the body manual, and things that I expect to be in the body manual turn out to be in the chassis manual, so you really need both.
Jimmy,
You might want to invest in a 1972 Assembly manual. It has a lot of the little detail items you seem to be looking for.
Heres a link to one of the suppliers. You can search the web and pick whoever you want to buy from.
http://cgi.ebay.ca/1972-Oldsmobile-C...item5ad2ed24a3
Good luck with your project. BTW, I have one of these manuals and it does have a lot of good info. The pages are all photocopied so the quality isn't as high as a first run publication but it gives me what I need in pretty straight forward terms. LOTS of pictures
pulling and replacing the dash is no fun at all for me. in 1999 i done a frame off, when i got to the interior i took a week off work to try to finish this car and it took almost the entire week to just put the dash and wire harness in the car. it was my first dash i did, i could do it faster now but don't want to do it again anytime soon.
Jimmy,
Actually,I think the dash is there to protect US from hitting all those gadgets they put under it!
I see how it comes apart now,it isn't like the 64-67 style,where the pad itself is one item,and the panel and components another. Thanks. ---bil
After getting it off and finally looking at it in the daylight today, I realized that there are some studs in the pad (that were shown in the manual) that should allow the pad to come off from the rest of the 'dash.' I don't know if or how that is possible while still attached to the car, and I still only see the backside of the screws, which means I still don't know how to get it off, but no matter. I didn't want to pick at it and crack something, considering I want it anyway.
Suggestion
You'd probably have to make them out of a bolt or screw and washer. Cut the bolt or screw head off, tack weld the washer in place and epoxy the assembly into your dash pad. I don't think you'll find these as replacement parts; they're not all that much in demand to tool up for production.
